Question about HTC P3300 Smartphone
Phone is slow
All of my sudden my P3300 has slowed down..When i click on contacts or IE it takes 1-2 minutes for the program to load. Sometimes i am not able to answer calls or even mute the ring!! Please help!!
  • 3 Answers
First backup all of your data...After that format your handset...
For format goto Start -> Settings-> System-> Click Clear Storage ...I hope your problem will solve
Posted on Aug 27, 2008
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
Jan 06, 2016 | Tablets & eReaders
Why is my words with friends not loading
maybe your wi fi is slow and that way it takes that long to load
Sep 14, 2014 | Apple Ipad I-pad
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Shortage of Virtual memory
uninstall programs on the p3300 and install them on an sd card.
save everything to the sd card.
delete internet files..
IE/menu/tools/options/memory/delete files
Jun 09, 2009 | HTC P3300 Smartphone
My htc 3300 is verry slow
it sounds like your phone has to much in the memory and is not running freely.
consider your phone like a computer, you need a certain amount of space free on your hard drive to allow the operating system to run freely.
if you have installed many games and photos and movies...remove some and see if your performance gets better.
another solution is that your battery could be loosing power from age. replace the battery and your phone will perform better witha new battery.
Jun 01, 2009 | HTC P3300 Smartphone
Slow internet on 1 computer
download atf cleaner to the desktop of the slow computer. open it , check the box that says "select all" then click on "clean selected". the first time you run this, it may take a few minutes. this program empties all the junk internet explorer saves, which reduces bandwidth issues. I run mine everytime i get off the internet. after the first run, it runs much quicker, and always run it twice or until you get the message "no files were removed" if you can't get to this point, you should run your virus scanner in safe mode. if your getting fast internet on the other three computers , it's not your provider, it's something between your router and your monitor, usually trash your web browser is trying to update while you are trying to surf. www.atribune.org/ccount/click.php?id=1
run this program , post again here if you need further assistance..
Regards..
Apr 16, 2009 | Computers & Internet
Mice MS9F96
Sounds like a sensitivity problem.
1) Go to "Control Panel"
2) Go to "Mouse"
3) There should be a slider bar that says "Slow" "Fast" just make it slower an it will slow down the mouse.
If this is only happening sometimes, it could be that your system is bogged down. You could try closing a bunch of programs that are loading on startup or getting more ram for your machine.
Oct 24, 2008 | Computers & Internet
My explorer get slow down
you were hit by some spyware
or you just need to unplug modem or router for at least a minute and let packs die out
now also you could have been hacked this could also slow a comp down doing the above proceedure will eliminate the hacker with the programs below while not connected to network after these programs updates unplug once again and then run software
use this free bee programs to clear system this should help speed up your comp its a spy ware destroyer
http://www.download.com/Spybot-Search-Destroy/3000-8022_4-10122137.html
this is one program update as soon as installed
http://www.javacoolsoftware.com/spywareblaster.html
and this is the other link do update as soon as installed
these programs are very good at what they do better than virus protection in my opinion
Jun 13, 2008 | Internet KM-2501P Enhanced PS/2 Multimedia...
Sudden PC slow down
Learn how to speed it up easily with some of the free PC speed up software.
best regards!
Dec 01, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
HTC P3300 Smartphone Logo
67 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
