Cant butnr a CD from my playlist in itunes. Got correct CDand everthign . Continually get an error message eg)"x00....." appplication error from itunes.exe When click on butn button....nohing happens. F drive is full
    Sergeant:
    Champion:
  • 271 Answers
Posted on Jul 31, 2008
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Error message stops install of windows xp
Open the case of the computer and look for a battery on the mother board ( looks like a large watch battery ) remove this for about 20 minutes. Put it back and re-boot the pc. You will have to reset the date and time.
Apr 26, 2009 | Computers & Internet
Toshiba laptop won't burn cd from itunes
I think that your cd burner is messed up. Try contacting Toshiba support, and asking them to troubleshoot it with you. This is the link for Toshiba support: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Apr 17, 2009 | Toshiba Satellite A205-S5879 Laptop
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
Mar 18, 2009 | Computers & Internet
I think it might have to do with Toshiba's OEM version of windows that is put onto the laptop. There is so many programs installed normally that i think theres system files that are incompatible with certain programs that require them. Probably a retail version of windows then installing just the drivers for the hardware and install just the software you want would take care of the problem in that way.
In the meantime though my other suggestion would be to use a program like Nero or Roxio Media Creator to burn your music onto cd's. That could do the trick.
Feb 08, 2009 | Toshiba Satellite L305D-S5881 Notebook
Rs 232 command Sony FWD32LX1R
Hello, i found the solution:
Screen off
^x8C^x00^x00^x02^x00^x8E
^x8C^x00^x00^x02^x01^x8F
Kind regards
Roger
Jan 05, 2009 | Sony FWD32LX1R Television
I had the same promblem. What you should do is make a serperate file on you desktop and drag all of your music that you burn or download to that folder first. Drag it to Itunes after that. Now, you only have to drag the songs to Itunes if you want them on there for you iPod. Take the songs from the folder, and drag them to windows media players burn list. Insert a blank disc and you should be good. Keep in mind that you can only do this if you put downloaded or burned music to the created folder first. If you take it to Itunes first, you will have to re-download or re-burn your music again.
Hopefully this helped you guys.
Nov 06, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Unknown Error 4900 on i Tunes and Windows Vista
I accidently lock the ipod and i forget how to unlock
Jul 29, 2008 | Apple iPod nano
Ipod nano
http://serviceman.site88.net/index_files/Apple_Ipod.htm
Jun 27, 2008 | Apple iPod nano
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
