Have tried a different monitor? Can you hear any sound when starting up the computer even though you get no display?Have tried a different monitor? Can you hear any sound when starting up the computer even though you get no display?
You can't post conmments that contain an email address.
Open the case, remove the cpu cooling fan, then remove the cpu itself. Under the cpu you will see many small pins. Cut off the one closest to the bottom left. This will permanently remove your SMPS so be sure before proceeding.
It sounds to me as the expensive part is OK. First try and boot from your System CD. If that works then your system software is corrupt and a repair is required. To do that, load the rescue/system disk and follow the "Repair your system" prompt. That will fix your problem, if that option is not available and the computer boots OK from the CD then re format your hard drive and then you can put a fresh install system on it restoring your data from your back up discs. Hope that helps.
there is defect on ur motherboard..
u system is forced to take a load of system failure...
ur system is hanged from boot,,
open the casing and reinstall the cpu fan and the processor...also do the same for ram
If the power light is flashing either yellow or orange and you do not hear any fans turn on, your power supply is defective. Contact Dell if you are still under warranty and if not, there are many 3rd party sites, like http://www.pcconnection.com, that you can purchase a new one.
