Can't get wireless card to connect to router
I have a cardbus card wireless LAN pc card IEEE 802.11b which has never had a problem connecting to any router before.
Im trying to connect to a netgear router - it finds the router when searching for devices - I click connect and it asks for key - I type in key (the one that appears on the side of the router) - Error message appears saying:
Password needs to be 40bit or 104bit depending on network configuration. Needs to be entered as 5 or 13 ascii characters or 10 or 26 hexadecimal characters.
The key on the side of the router consists of 8 capital letters.
I have no more information on either the router or the wireless card and have no idea what to do.
Any ideas? Gem x
  • gemmaredgrif Aug 02, 2008
    I have managed to find the correct code for the router but another problem has occured. The laptop finds and connects to the router, the main pc recognises that I am trying to connect to the network but something is stopping it connecting properly. It seems as tho my laptop is sending the right signals but the router isnt happy to have me!
    Do you think this could be the wireless card? It is quite old - I thought maybe if I bought a new one and set it up from scratch to this router it might work?
    Problem Solver:
  • 26 Answers
Based on the error you posted, the network key you are trying to enter does not match the network key configured on your router. to make sure you get the correct network key, you will usually need to check it on the router configuration. I may be able to help you find that network key if you can provide me the brand and model number of your router.
Posted on Jul 31, 2008
  • Leonelo Sanchez
    Leonelo Sanchez Aug 03, 2008
    You may try the following suggestions before gettting a new wireless adapter:
    1. Remove other preferred networks on the computer and leave only the network for your router. You can find this setting on the wireless networks tab of the wireless connection properties.
    2. You may also try to change the channel on your router. This will lessen the interference and might give you a stable connection.
    3. Check for updated drivers, since your wireless LAN card is quite old, it might have updates that might improve its performance.
    4. If you are using Windows XP, it is recommended that you use Service pack 2, which contains a lot of updates regarding the Wireless Zero Configuration (XP's built-in wireless service)
    4.You may want to test other wireless computers if they connect fine on your router. In this way, you will be able to determine if it is really the wireless LAN card or could also be your router.
I get dr-655 configuration screen instead of ENHWI-2AN3 screen. Both my router and access point use 192.168.0.1 as the setup screen. how can i access the encore wizard instead of my router page?
Whenever you assign the same IP to the both the Modem and Router, this sort of this happens. In order to access the Modem, you have to either remove the router OR connect directly to the Modem (ENHWI-2AN3) through a patch of network cable connecting the cable at any of the LAN ports (yellow ones) and LAN card of your PC/Laptop.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 11, 2011 | Encore ENHWI2AN3 IEEE 80233u IEEE 80211bg...
TP-LINK TPLink TDW8950ND 150Mbps Wireless Lite N ADSL2+ Modem Router IEEE 80211 bgn 4x LAN Ports - my laptop windows xp can connect to internet by using lan but my desktop is no internet access with it. is...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
Apr 14, 2011 | Computers & Internet
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
I cant connect to the internet through my wireless
I cant connect to the internet through my wireless but it sows connecton
Aug 17, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Wireless card driver needed
Appreciate the direct "Ask Me".
To your concern, does it look something like the image belwo?
If yes, it is as you posted, a 802.11b Wireless LAN Cardbus Adapter distributed by GetNet Technology Co., Ltd. with model # GW-9106PC. Pls find driver and manual download from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Computers & Internet
Wireless connection
before you insert the card to the slot run the cd thats comes with it and install the software. after installation of the software insert the card. if it is properly installed, you will see a single computer icon on your task bar click it up and search for a network.
Feb 11, 2008 | Computers & Internet
Wireless cardbus pc card tew -601 pc
Hi..thanks for ur suggestion..my problem has been solved by opening my computer - properties - hardware and clicking on device manager and thr other device showing yellow question mark and i thought wirelss device doesnt work properly and i cliked on update device..a nd now my pcmcia card works fine
Thanking you
Neethan
Computers & Internet Logo
306 people viewed this question
David Payne
David Payne
