Question about IBM ThinkPad 600E 2645 Notebook
Ibm e600 laptop screen
Hi i hope you can help me, i have a ibm e600 laptop, the screen has gone very dark black but not off as i can still just about make out the icons on the desktop, it eventully shuts down. i have replaced the inverter but this has not worked. i am thinking of replacing the screen but wonder if it might be a bad connection to the screen? hope you can help!
Thanks
Joe
  • 846 Answers
There is a possibility it is your backlight because the laptop is probably older than 3 years, then you have to replace the ccfl lamp of the screen. It is a difficult repair but it can be done, if you look for guides online you will find something. I work for company that does Laptop repair in NYC and we do this repair frequently.
Posted on May 19, 2009
    Genius:
  • 2,028 Answers
With these machines the inverter is always first on the list. Since you've ruled this out, it's going to be the screen or cable. I'm leaning towards the screen. Inspect the cable and connectors thoroughly for any flaws that may create a bad connection. Generally when this occurs and the inverter is ruled out it's the back light in the screen versus the cable. The screen is a sealed unit so the back light cannot be changed out. I suggest a new screen. I browsed Ebay and you can get a screen with the cable for under $40, I'd go that route.
Posted on Jul 31, 2008
The screen is too dark to read
See if there is a contrast adjustment somewhere on the laptop first, if not then its a possibility your back light has gone and needs replacing.
Jan 19, 2010 | Acer Aspire 3000 Notebook
IBM R50
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 22, 2009 | IBM ThinkPad T23 Notebook
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad R31
It looks like hardware problem.
Nov 08, 2008 | IBM ThinkPad R40 2722 Notebook
IBM T30 screen has gone dark .
Above the upper right corner, there is a littlesquare nutch that turns the screen dark when the lid is closed. In most cases it's stucked. poke it with a pen and see if the light turns on.
Sep 19, 2008 | IBM ThinkPad T30 2366 Notebook
Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Jul 28, 2008 | Acer Aspire 5100 Notebook
Laptop screen gone dark
I had a similar problem on my Fujitsu-Siemens Lifebook C-1020 and I had to replace both the C/C inverter that the CCFL lamp. Easy to find/replace the inverter (only take care of input/output plugs), tricky to find/replace the CCFL lamp (because of diameter, lenght and toxic Hg content).
Zpp
Have fun!
Mar 09, 2008 | IBM ThinkPad T42 Notebook
Dark screen
Your backlight is probably burned out. It is repairable, but I recommend having a computer repair shop take care of it.
Jan 28, 2008 | IBM ThinkPad G40 Notebook
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
Laptop screen is barely readable, cannot not determine location of cursor.
i am having the same problem, my screen apears to be pretty nuch black until i have to tilt it up to be able to slightly read the dark screen.
May 24, 2007 | IBM ThinkPad R51 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
190 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
