LG TV Model RT-21FB70V When switched on, the light does not come on the front, the picture does not come on, a clicking starts internally, then a high pitched chirping. The fuse is good. There is no obvious burnt components on the cct board. Does any one know what it might be?
  • 375 Answers
SOURCE: Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
  • 1694 Answers
SOURCE: Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Posted on Oct 18, 2007
  • 395 Answers
SOURCE: Samsung PCL542R Chirping noise
the high pitch chirping noise is coming from the power supply. there is a short circuit with the switch mode power supply. check the HOT(horizontal output transistor) first then the power supply for shorts. on the HOT check for short between base to collector, and emitter to collector. base to emitter will show short because it in line with the primary coil of the fly-back transformer.
if you are unfamiliar TV repair have a tech repair this for you.
Posted on Feb 17, 2008
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
How to fix a lg tv 47inch with black screen no pictur 47LB5900 model
The red light merely indicates power is getting to your TV. There may be an open internal fuse or power supply failure.
Jul 17, 2016 | LG Televison & Video
I have a 15 inch TV LG Smart TV something went out on it what could it be the model number is 50LN5700UH the LG light comes on but no picture
LG TV : Picture not coming on screen, but TV is on. - Forums - CNET
www.cnet.com > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ... LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from www.cnet.com
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
Oct 20, 2015 | LG Televison & Video
My lg projection tv model rt 62na31rb curved color problems
you need to adjust the convergence setting on the tv.
http://www.youtube.com/watch?v=esk4nYZKFcg
enjoy the groovy music on the video
Oct 08, 2014 | Televison & Video
Lg rt 56nz23rbLG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no picture and than switches off by going into stand by position.The horizontal and vertical outputs...
Thus problem sounds like you have some failed capacitors on the power supply circuitry. I have had this problem on an older TV and it was solved by replacing the popped caps. Do not try this repair yourself, unless you are confident you can do so safely! Also make sure that you unplug everything before poking around inside!
Mar 19, 2014 | Televison & Video
Hi, i have an LG plasma, model number RT-42PX11.
You need to pull the power supply out and replace the damaged caps on the board. Look for swollen, pushed up tops and leakage around the base of the caps.
You need soldering and basic electronics skills. You also need to pull apart that big tv and pull the power supply board!
You can look on Ebay for pullout boards from people who have broken their screens. It can get you a working board for cheap sometimes!
Good luck and be careful!
May 07, 2010 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
I own a LG rear projection tv model number RT - 44NZ31RB and for some reason refuses to turn on. Worked fine and then all of a sudden stopped. Standby light comes on and then a small noise can be heard...
had the same problem as described, exactly. happend after 13 months of use.
I had the power suply replaced and it works perfectly since then.
Jun 30, 2008 | Televison & Video
Check your horizontal output and regulators also vertcal output.You have a deflection problem either Horizontal or vertical outputs or one of the regulators are faulty. Let me know if you require more assistance.
Feb 02, 2008 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
