Question about Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool dishwasher ADP905
Green start light keeps flashing and dishwasher won't run.
    Problem Solver:
  • 8 Answers
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Posted on Jul 31, 2008
  • rach_cam_mas
    rach_cam_mas Nov 30, 2012
    Thanks! Worked for me :))
Your filter may be blocked, take it out & clean it. Or, your drain hose may be off, or leaking, or not mounted high enough so that the discharge point is level with the top of the machine. If the machine does'nt detect a water back pressure in the drain hose, it thinks the hose is missing & so to avoid pumping water all over the floor, it switches itself off.
Fix the hose, (or clean the filter) then depress the start button until green light stops flashing. Switch electric off & then back on again. Then touch the start button.
Posted on Oct 12, 2008
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
W/p adp905 d/w has not been used for some time it now trips the electricity out just after starting
The motor is set up... take it apart anf free up the motor and it may work...
if not you may have to change the motor out...
heatman101
Sep 16, 2010 | Whirlpool Dishwashers
Whirlpool ADP951,not operating
My advice, go buy a new one. If money is tight, go to the clearance aisle at Home depot and look for a scratch/dent discount model to replace it.
Old dishwashers were never good from the beginning. No point in fixing it - it was never designed well.
Nov 20, 2009 | Dishwashers
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp5962
you may have water in the base due to a leak internally.if you tilt the dishwasher backwards and water runs out.thats the cause of the problem.on all the whirlpool full size dishwashers .access to the base is through two t25 torx screws securing the base plate.
Dec 04, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool 24 in. ADP6940 Dishwasher Logo
1,235 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
