Hardware monitor found an error
Everytime i open up my computer thereis always a messge that "hardware monitor found an error.
please help me!
Diagnosis: Lack of P.S.U. fan speed report indicates P.S.U. fan sensor damaged by overheating. This was caused by cooling fin blockage since the Sony design on this model cools the C.P.U. THROUGH the P.S.U.
Expert level fix: Remove P.S.U. Remove C.P.U. fan and vacuum. Remove C.P.U. cooling fins from C.P.U. and cooling fan mounts from fin box, vacuum. Reassemble C.P.U cooling system. Replace P.S.U. with O.E.M. part only since in this case it is proprietary to the unit.
Posted on Jan 27, 2010
Thats not true.... it means u either misconnected a cable from ur power supplie to ur motherboard, or u have a component in ur pc (for example cd or dvd drive) thats causing it.
Posted on Nov 06, 2008
    Sergeant:
    Champion:
  • 271 Answers
Your windows XP is corrupted>>> those kind of errors occur can be cured only after reinstalling the OS
<PLEASE RATE ME AS FIXYA>for my help......................
Posted on Jul 31, 2008
Dvd drive always says
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jul 22, 2012 | Computers & Internet
Error messge "Check Signal Cable"
Your Lcd monitor i guessed is working. Try to check your system ram or memory and video card. You must discharge your electro static in your hand first before touching any of the computer components because it is sensitive to electro static, you must hold the computer casing for about 1 minute only. Then unplug the video card and memory and clean the pin using eraser to remove the dust and brush (small paintbrush) it also. Dust can cover the video and memory pin which will not be detected by your motherboard.
Please rate me.
Nov 19, 2010 | Samsung SyncMaster P2450H 24" Wide TFT...
I'm having trouble scanning a document. It comes up with an error that thereis no communication. It does print??? Any ideas?
clarification please. well sometime and i chance usb port and it works. or restart your computer. there should be a software that you download onto your computer that comes with the printer. you should open the software everytime you scan/print something.
Feb 12, 2010 | Canon MX700 Office All-In-One InkJet...
Hi! i have a computer but everytime i play games it always hang-up..what will i do with this problem?
it may be overheating. it will cause ur computer to freeze
Check ur cpu temperature from BIOS in "hardware monitor"
Feb 05, 2010 | Computers & Internet
My hardware monitor found an error how do i fix this.
Hi:
Usually the hardware monitor is trying to tell you something, like a fan is failing or something is getting too hot. You need to open the hardware monitor page and see what the actual error is. On boot up, you either hit Delete key or F1 and then tab over to the hardware monitor page.
Nov 19, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
May 22, 2009 | HP Computers & Internet
Deepfreeze from my computer is not working properly
try uninstalling deepfreeze, it might solve your problem.. to uninstall deepfreeze, you must run the Installer file of deepfreeze..
Feb 03, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Computers & Internet Logo
279 people viewed this question
David Payne
David Payne
