What is the problem with my laptop if the screen flickers?
    Sergeant:
    Champion:
  • 271 Answers
Screen resolution or refresh rate might be exeded its limits...
<PLEASE RATE ME AS FIXYA>for my help......................
Posted on Jul 31, 2008
My aspire 5830t screen flicker at startup
I suspect the backlight or inverter may be faulty. Check on flea bay for replacement prices.
Dec 21, 2013 | Computers & Internet
Hp g6000 screen
Please explain the events that lead up to your screen flickering ... in detail, from the time you turn the laptop on. Does the splash screen flicker?
Sep 07, 2013 | Computers & Internet
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Flickering screen
Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Mar 28, 2012 | ASUS U52F-BBL9 Laptop
My laptop screen flickers in and out, screen goes black
Hello there,
The reason the screen flickers is simply because the module of the laptop is faulty. The module is what connects the screen to the main board, it is like a flex for the screen. Once you can have it replaced, the screen will stop flickering.
All the best Elect_Comp
Sep 13, 2011 | Acer Computers & Internet
My acer aspire 7535-5020 screen flickers sometimes the screen will go completly white
First you will need to determine if there is a problem with the laptop screen or the video card.
Plug in an external monitor to your laptop and use your laptop, if the screen on the external monitor flickers the same way your laptop screen flickered then there is a problem with the video card and you will need to repair your laptop. This is considered a major repair because the video card on the laptop is usually embedded into the motherboard and will be expensive to replace.
If the screen does not flicker then the connection from your laptop to your laptop LCD display might be loose. You will need to remove the cover of your laptop and make sure the connection is firm, as well as make sure there is no damage on the connector or wires.
Hope this helps.
Mar 16, 2011 | Acer Computers & Internet
The screen flickers periodically without any reason. If i giggle the screen or pull the screen down the up it staops.
Hi
The flickering happens because the flex of your laptop is getting weak.
The flex connects the screen of a laptop to the motherboard it is through it that data is passed to the screen.
It is found in all laptops and the more you open and close the laptop,it gets weaker and weaker.
The best thing to do to stop the flickering is to change the flex.You can also loose the laptop,remove the flex and fix it back properly but that may not stop the flickering permanently.
Note;if you cant loose the laptop yourself please get an expert to do it for you
Thank you for visiting fixya
Mar 12, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Flickering laptop screen
flickers..sounds like a problem deeper than the screen..what kind of pc laptop are you using. and please provide the model number?
Nov 21, 2008 | Computers & Internet
Acer notebook aspire 5102 WLMi screen flickers
Hardware, sound like the cable that attach to LCD panel was losing...
Nov 17, 2008 | Computers & Internet
Lcd Flickering
Sounds like the driver board for the backlight is going bad...is there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
