Computers & Internet Logo
Anonymous Posted on Jul 31, 2008
Can i put G-force that is one computer and transfure it to a vista computer. with out have to get a new license.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
19
Points
i found my license & download it strait to my vista computer
2answers
How do i put my Vista on a DVD, so i can put it on another computer?
I don't think a Microsoft operating system, including Vista, can be copied. The operating systems are proprietary and licensed by Microsoft, and the product key can not be transferred from one computer to another.
I want to save intallation and install it to another computer
If you still have youir Vista license key and it is retail (not OEM), then you will be able to transfer your installation intact. Use windows vista system (not file) backup to a portable HDD. Also make a rescue disk. Then boot to the rescue disk on the other computer and follow the prompts to recover the main backup you made. You will need your license key to activate the new Vista. You may need to tell Microsoft that your old computer is no longer working to transfer the license. If the old license was OEM, you can't move the license (it is for the life of the original computer/motherboard only), and you will have to buy a Windows 8.1 pro license and migrate your data instead. I have done that from windows Vista 32 bit to Windows 7 64 bit. I used all different types of backups (including Mig, vista file backups, copy my whole profile) and carefully put it all back together. Let me know if you want more help with anything specific.
I am in a company that does not have license for all the computers. Recently we received a letter that lawyers will verify licenses. Can I buy a license from any dealer and have it installed in the Pcs ...
That's a great idea and thank you for supporting legal copy of Windows software. My answer to your question is Yes! Definitely, you can buy your own license and install it in your computer. However, I assume that all authorized retailer of Windows are only selling Windows Vista version and up. But if you encounter a store that still sells a legal copy of Windows XP, you can grab that copy. But before buying a software, please check the specification of your computer and make sure that it is compatible with Windows 7, in that way once you have the Bootable CD you will not encounter any problem.
I hope I answered your question.
Thanks a lot!!
How to get 99 blazer out of 4 wdlo to 2 wdr hi when push button wont work.
This has a Borg Warner 1350 series transfur cast. cLimb under the truck with a 10 mm socket and rachet and remove the 3 bolts holding the electric transfur case motor, Looks like a soda can. Once removed ,you will see what looks like a try-angle shaft turn it twards the right. You have just moved the low-high fork. Put the motor back on and pull the 4x4 fuse until you change the 4x4 motor
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
Recover an Acer 3680
waharris007,
I had the same problem...I originally thought it might be a ram chip and I started testing them...Turns out that the second ram socket was bad and I just had to remove one of the ram chips.
I can't get my system recovery disk to work so i can restore my computer to the orginal format
If your recovery CDs have failed you have some options
1. you can call the company who made your computer about a new set of restore discs
2. you can buy an operating system disc such as XP or vista
XP or Vista , Operating System Installation CD will setup the computer nicely , you may need drivers for certan things but not likely.
Malfunctioning restore CDs really **** me off
I just chunk em and load my XP pro disc
( multi machine volume license required if you wanna put it on multible computers )
( same with vista )
but in some cases you may find that XP pro will install on many machines just fine.
Thank you for using FixYa!
Az.
Vista
Legally no. Micorsoft states that every Windows machine must have it's own operating system licensed to it.
When setting up new computer, Windows Vista keeps asking for Product key number to secure computer. Will not accept this number that is on the new computer
maybe your vista license is for one computer only that's why will not accept the serial or product key you need to purchase another windows vista software with license
Windows vista
witch licensing key
hdd licensing key or
wista licensing key???
Grand Canyon Tech
Grand Canyon Tech
