Question about Kenwood KDC-MP628 CD Player
Subwoofer controls I just hooked up an amp and subwoofers to my unit. I can't remember how to get to the subwoofer controls on the player
  • tonyanaek Jul 31, 2008
    kdc mp 628
  • Anonymous Mar 10, 2009
    i have a kenwood kdc-bt742u and need to get back to my subwoofer controls....system needs more BASS!
  • 476 Answers
What model of head deck amp & do have???
Maybe I can help
Posted on Jul 31, 2008
Hooked everything up in my car right but still no
hook your personal music player to sub amp turn on see if it works if so check settings in head unit or rca wires
Sep 07, 2014 | Car Audio & Video
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
Nov 16, 2011 | JVC SP-PW100 Subwoofer
How do u hook up a dual voice coil subwoofer ?
A dual Voice coil Subwoofer is like having two speakers in one, but the inputs from the amp to the sub must be the same level or you can over-heat the coils. Simply hook the subwoofer to your amplifier as if you had two separate speakers, make sure you get the + and - correct. If there is a level control on the amplifier for Left and Right, be sure to set these at the same level, also if the head unit has a subwoofer output for the amplifier be sure to use this
Hope this Helps GM
Apr 05, 2011 | Kenwood Car Audio & Video
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
My subwoofers will make no sound now
Go through the multiple menus of your head unit, and make sure the subwoofer setting is set to "yes".
Do you have the owner's manual for the unit? What make/model is the head unit?
Mar 06, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Subwoofer doesn't play through ipod, only radio and cd's
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Kenwood KDC-MP628 CD Player Logo
163 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
