Question about Motorola Mobility RAZR V3
Motorolla Razer V3i Keypad is not working
I have change my phone ring style to vibrate mode yesterday, after that my keypad stopped working... if i get a call i can accept it by making the phone wide open. But am not able to disconnect the call. While the call is active no other keys works too. I have connected the charger and the vibrate mode changes but still keypad dosnet work. When i disconnect the charger its going back to vibrate mode.. Can anyone help me.pls
  • 1 more comment
  • amy50 Jul 31, 2008
    I am having the exact same issue!!!! Did you find someway to fix this?
  • aaronyacooba May 04, 2009
    I always get voice recording
  • Anonymous May 13, 2009
    v3i keypaid is not working how can i solution this ?
    Scholar:
  • 87 Answers
The best way I can recommend to fix this is to contact www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited.
It sounds like some moisture has gotten into the bottom of the phone and is shorting out the keys.
If you want to try it yourself, you need to replace the keypad flex
Posted on Jul 31, 2008
2 Suggested Answers
sonu_sehgal
  • 421 Answers
SOURCE: Motorolla Razer V3i Keypad is not working
sir it is hardware problem because of vibration it damaged
Posted on Jun 02, 2009
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Vibrate
1 go to settings
2. ring style
3. click the little button top left on phone under "select". it will let you change your ring style
4. scroll to vibrate
5. click same little button under "select"
6. keep clicking "back" - the little button top right on phone under "back"
Jan 29, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
Jun 02, 2009 | Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Changing Ring Style
scroll down and it takes you straight to the ring styles and u can pick it straight from there x
May 20, 2008 | LG Shine KE970 Cellular Phone
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
717 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
