When i turn my pc on it tells me in a blue box no signal but the pc keeps running but i cant see anything i bought a new graphics it still doesn't work i bought a new monitor still doesn't work
  • 981 Answers
The No Signal thing is your monitor saying it doesn't have anything from the PC to display; the PC has nothing to do with that.  Try refitting the card to the PC to make sure it's in there right, and if your PC boots then you should see something (especially if your cables are all plugged in right and your monitor is paying attention to the interface the PC is on, not some other source it could be fed (e.g. SVHS, composite, DVI-D...)
Posted on Jul 31, 2008
I am trying to replace the rear turn signal on my 2001 Sportster. The signal that is on it now has a blue and a black wire. The new one only has a black wire. How do I make this work?
Before you take anything off or hook anything up, take the bulbs out of both turn signals. Look at the base of the bulbs and see if there are two or only one connections. I'm thinking you bike has rear running lights and the turn signal unit you are trying to replace it with only has the turn signal capability. Before you connect any wires, make sure the black and the blue wire on the bike are not touching anything metal. Turn the turn signal on and see which wire is hot. It probably won't flash but it'll go "hot" when you press the turn signal button. If they both only have one filament in the bulb, one connector on the base, then wire the blue wire on the bike to the black wire coming out of the turn signal. This would be my guess as the ground for the turn signal is a physical ground. If it doesn't work, try to connect the black wire to the turn signal body to make sure it's got a good ground. Now, there is the possibility that the turn signal will not work at all. Your bike is equipped with the automatic turn signal cancelling unit and they are very picky. It may sense the mismatch in the parts and not work at all.
Good Luck
Steve
Jul 22, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
I have just bought an acer aspire x3400, I followed all the installation instructions, turned it on and the monitor came on, displayed the word Acer, then a blue box popped up and said no signal and the...
Make sure the cable to the PC is secure by tightening the screws on each plug. If the problem still exists then you need to take it back to the shop where you bought it from. It could be a fault graphics card or connector.
May 28, 2011 | Acer Aspire X3400 PC Desktop
My pci Express is8500Gt.my desktop is celoren D,1.80Gz.250HDD,ram 1gb. last week i install it and play nsf Carbon,everything is allright.2 days after when i go to turn on my Desktop then i see my monitor...
If your graphics card works on another pc but not on yours then you should try another graphics card on your pc. If it also doesn't work it means it's a problem with your motherboard.
May 24, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
Vertical lines on monitor I have a dell dimention 8300 computer with a 128MB DDR ATI Radeon 9800 pro graphics card. Yesterday when I turned on the computer, I had 5 sets of vertical lines on the flat panel...
by process of elimination, try unplugging your monitor from your computer. turn it on, the built in self test should run. it will give you color coded boxes like red green, blue etc.. and would tell you no signal. if you cant see any lines during the buit in self test, then is the video card thats busted...
Hope it helps!
Feb 07, 2010 | Computers & Internet
Binking blue power light on LX6200-01
unplug the ram & cleane the ram and then try again
Oct 03, 2009 | Gateway LX6200-01 PC Desktop
P c game
If you don't tell us anything about your pc its hard to give good advice but.
It seems the game you bought is too new for your pc and requires a better videocard to run it.
Without haveing much information about the pc I can only recommend buying a new videocard.
Mar 02, 2008 | Compaq (VSXXXAB)
Compaq 510s sff. Graphics Card
Hi Mikey You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP 1- turn your computer off (Shut Down) 2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen) 3-find your desplay/graphic or anything that is related to graphic. 4- Change it to AGP Now it should work but if it didn't work: 1- Faulty Display (Monitor) 2- Not compatible graphic card(rearly) 3- loose or damaged cables 4- Damaged Motherboard please let me know of your progress Kind Regards
Oct 07, 2007 | Compaq EVO D5S SFF Refurbished Desktop...
Computers & Internet Logo
David Payne
David Payne
