Question about LG 1000W XM-Ready 5.1-Ch. Home Theater System with 5-Disc Upconvert DVD/CD Player
Sound with television
When i watch a dvd the sound works fine but when i press the simplink buttion and try to use the hometheater with tv programs the sound doesnt
  • 1 more comment
  • kerih Aug 30, 2008
    Yep, we have the same probem with our LG HT903TA, we purchased the unit to get surround sound from our new new LG plasma hd and foxtel hd. The manual instructs for 5.1ch ez set-up - to connect the unit's optical in jack to the jack on optical out of our tv, did that; no sound! When playing a dvd in the unit, crisp, wonderful surround sound but when we watch tv or foxtel hd - only the two front speakers give out sound, that sucks! Cannot find a solution, very disapppointed.
  • snarkyroxy Jan 03, 2009
    Same problem here. Can't get surround on the TV or on the LG blu-ray player which came packaged with the HT903TA!! Only comes out through front-center, left and right speakers (no subwoofer either from what I can tell).
    Had it all professionally installed by the shop I purchased it from (along with the plasma TV) so I assume everything is plugged in correctly via HDMI, optical audio etc.
    Not so fussed about surround while watching TV, but it's ridiculous to only have 2.1 channels on the blu-ray!
  • Anonymous Mar 30, 2009
    connect optical from set top box to home theatre system
On the LG DVD remote press the VSM button (just to the right of the volume button) until PL II MOVIE is displayed on the DVD front panel. This will send sound to the back speakers as well as the front.
(I still don't think this is true 5.1ch surround sound however but the cloestest I've been able to get)
BTW you'll need to have an optical audio cable connecting the Plasma / LCD and the DVD. DVD input will need to be set to AUX OPT.
Posted on Jan 08, 2009
I have the same problem, has anyone found a solution?
Posted on Nov 13, 2008
My plasma tv will turn on by remote but then all the other buttons won't do anything.
Are you using original remote of TV ?
The universal remote may not be programmed correctly or compatible to your model of TV, DVD. Compatible Devices MyURemote Universal Remote Control App
Apr 15, 2016 | Televison & Video
Installing a LG Network Blu-ray Disc/DVD Home
Jun 19, 2010 | LG Televison & Video
Hi I have A LG50PG20 the sound in the tv speakers wont work but when I use simplink it works trough the dvd speakers
That is the correct function of the SIMPLINK.
If you look at the bottom of the page of #44 in your user LG TV manual, you can read about the SIMPLINK issue.
“When you select a device with a home theater functionality, the sound output automatically switches to the home theater speakers.
You can turn off the SIMPLINK function to stop this issue. Go to "Menu", select the white "Toolbox", and look down and you will see the SIMPLINK to change its ON/OFF option.
Good Luck.
May 20, 2010 | LG 50PG20 50 in. Plasma HDTV
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Sansui tv
sounds like the tv is on the wrong sorce
Apr 12, 2008 | Televison & Video
Getting sound when in telly mode
You have to use the switch on the pro - logic simulation. Your remote button might say sound or PII(with an icon). Usually if you continue to press the buttion you will cycle this different presets, ie. Music, Movie, Cinema, etc. These are optimized for the type of media your using, but try them all and see what works.
Jan 04, 2008 | Sony DAVHDX265 System
Home theater system connections
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
LG 1000W XM-Ready 5.1-Ch. Home Theater System with 5-Disc Upconvert DVD/CD Player Logo
538 people viewed this question
Top LG Audio Players & Recorders Experts
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
