Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Link doesn't seem to have any information on Viking dishwashers.
I'm not sure if it is an error code since there isn't a digital display, but the lights continue to all blink at the same time continuosly.
  • 13,433 Answers
Sorry for the delayed response, you can click on the request more assistance button or repost the problem, I don't remember what the button says but other solutions have been offered by other experts.
expert toddg has suggested that there is a 5 year warranty, is it over 5 years old?
if you don't see hes solution just click on the repost problem a few times.
Posted on Jul 31, 2008
I have a brand new Viking dishwasher and it won't start. I get an error code "E 02". Can I fix this or do I have to call Viking service?
Hey Marlene, Your new washer must have a warranty.. use it.. call or go to the store where you purchased it... they should take care of you!!
Sep 23, 2017 | Viking Dishwashers
Dishwasher Repair
get in touch with the retailer
Oct 19, 2014 | Viking Dishwashers
Dishwasher doesn't seem to be getting power. Breaker looks good
first check the power connection behind the toe-kick pane,then theres a fuse in the control panel to protect the electronics which can open and kill power to the unit
Aug 02, 2011 | Viking DFUD042P Built-in Dishwasher
The dishwasher doesn't seem to drain water.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 10, 2011 | Viking DFUD04 Built-in Dishwasher
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
What does an E3 code mean?
hello,
what this mean is an indication of a problem detected b the sensor
Some models of washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of washers may vary in their fault displays.
thanks
Oct 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Mar 27, 2010 | LG 24" Built-In Dishwasher - Black
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Thanks
Jun 27, 2008 | Dishwashers
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
124 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
