Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Can you fix the problem with my laptop
I have a laptop that the mother board fried,i tried replacing it myself. It turns on but the screen is dark and you can barely see what its doing.Is it possible to fix the laptop still and if you can restore it like new,how much much would it cost?
  • brambi1 Jul 31, 2008
    i'm trying to save the memory that it has
  • 52 Answers
NEED YOUR PC/LAPTOP REPAIRED......
ARE YOU HAVING ISSUES WITH YOUR PC OR NOTEBOOK NOT WORKING THE WAY YOU EXPECTED
well if your having issues with your wireless/black screen issues/bad-slow performance/
nb settings/error messages/recovery and restore/Internet Explorer/pop ups/Microsoft/sound
/software/hardware, pretty much anything at all why not try me FOR FREE at moonbayboys@hotmail.com
....i also help with the removel of virus/spyware/malware
this one is free...start the nb and hold down f11
Posted on Jul 31, 2008
TV turns on, but the screen is very dark, almost completely black.
It sounds like your backlight is out or barely functioning. Try replacing the inverter board(s). Since you can see a picture, the T-Con board is probably okay.
Apr 20, 2017 | Polaroid 2611-TLXB TV
Screen dark on monitor
1. you possibly have a malfunction inverter board which is internal to the PC.
2. this will require a qualified tech to dismantle the pc and replace the component board that connects to the video card that is integrated to the mother board.
2. if the video card is not working this will require a new mother board to be installed.
3. there is a cable also in some models that connect the video display to the mother board and this cable could have be dislodged and the results is no screen.
Oct 11, 2011 | Compaq Armada M700 Notebook
I turn on the pavioliion dv4 and there is no screen. i hear it on but see nothing
http://www.ehow.com/how_6162556_change-screen-brightness-hp-laptop.html This is a link to with instructions on how to change the brightness of your computor. It may be on too dark a setting now. Another possibility is that the screen has worn out and needs to be replaced. A third is that the computor itself is not working properly now, although you say you hear it on. If it is not a question of brightness (the setting is too low and now everything looks dark), I would take it to a place which repairs HP's.
May 03, 2010 | HP Pavilion dv4000 Notebook
Motherboard is fried.. apparently due to water damage. how do i fix this myself.. the computer worked fine for months after spill now it wont even turn on!
Replacing a laptop motherboard is a daunting task. If you have never done it before, it will take hours to do and there will be a lot of frustration involved with taking it apart and putting all back together. The mother board will also be pretty expensive by itself and likely to be difficult to find. If you are trying to keep costs to a minimum, you might try to find an equivalent system at a site like pacificgeeks.com which sell refurbished and used systems with a 30 to 90 warranty at some amazing prices. With a laptop that is badly damaged, I usually find that it is better to replace than to repair.
Feb 11, 2010 | IBM Thinkpad T61 Motherboard
Motherboard is fried should the proccessor be replaced too
Not necessary to replaced. First fix it with you new mother board and try to run. If that time its not working then replaced it. Before replaced just confirm its damaged.
Thanks.
Feb 06, 2010 | Acer Aspire 5920-6574 Notebook
When I switch on my dell 1535 Studio laptop with the power button and then either move the hinged screen or the laptop, there is a noise which sounds like the laptop is switching off. The screen freezes...
Hi Friend,
You dell 1535 is creating problem in mother board. may be your RAM and mother board creating some problem. so you need to contact any hardware Eng. ...
Dec 20, 2009 | Dell Studio 1535 Motherboard - H281K
Real dark screen on Toshiba A135-s4437
First I would check to make sure that the contrast/brightness buttons on the laptop weren't accidentally changed, making the screen dark. Also, try with and without the battery and power supply. Otherwise, unless it is actually the screen that is defective, it is usually a power converter replacement, which is a small circuit board, usually under the plastic cover directly under the monitor, which supplies power to the monitor. You may want to take it to a shop as they can isolate the issue easier.....
Mar 10, 2009 | Toshiba Satellite A135-S4437...
My laptop does not turn on
No idea why they fixed the problem then said it is the motherboard. There are times though when the motherboard is actually bad and it does need to be replaced even with replacing the jack. With a motherboard it has to convernt electricity and sometimes the wiring is fried or bad. But if it works then let it run, if not, I would take it some where else and have another company check to make sure that they did not melt the board causing it to be a board problem
Feb 20, 2009 | HP Pavilion ze4300 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
