Question about Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP
Converting a range from LP to Natural gas
Is it possible to convert a 48" Jenn-Air Gas Range from LP to Natural gas.
    Sniper:
  • 68 Answers
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Posted on Jul 31, 2008
How do I convert a Jenn Air PRG 4810 from natural gas to lp?
Many gas stoves anymore have adjustable orifices. and they just need to be adjusted to propane .
Mar 09, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting broiler in oven from natural gas to lp gas on hotpoint gas range
On the oven portion you will need to turn the oriface clockwise all the way till it bottoms out. This is the conversion from natural gas to lp gas on all gas ovens. Also make sure the valve down toward the back has been flipped off of nat. to lp. Good luck
Mar 02, 2010 | Hotpoint RGB745 Gas Kitchen Range
Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Jan 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP Logo
341 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
