I'M HOOKING MY XBOX 360 TO A WIRELESS ROUTER FROM THE COMPUTER AND THE GME SAYS MY DNS FAILED!
  • 981 Answers
Yeah, DNS is the domain name service that sometimes sucks depending on the ISP and day of the week; there's an OpenDNS.org you can try on the XBox to get things going if the ones from your ISP can't satisfy; but it might also be that you need to explicitly allow DNS routing for the XBox.
Also, your problem description is lousy because I can't tell what the data path to the XBox is; off the router, to your PC, and again on a cable from your PC to the XBox, or what?  Take off all-caps and explain what router you have...maybe make a new question under that router's model name, since that's the issue...and how you think the XBox ought to have internet connectivity.
Posted on Jul 31, 2008
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Mar 14, 2010 | Microsoft Xbox 360 Console
I am trying to connect to xbox live through a router but it says the dns has failed can anyone help
Here is support from Microsoft about the 360 and DNS FAILED error with xbox live. Hope this helps you out.
http://support.microsoft.com/kb/908884
Please don't forget to rate. :)
Apr 08, 2009 | Microsoft Xbox 360 Console
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
My Xbox 360 ADapter Cannot Aquire a IP Address from my Modem
can u please tell me which router it is? in most of the router there is a feature call DMZ. u need to enable the DMZ in the router & then u need to provide the static ip to Xbox 360 like 192.168.1.5 etc in the default getway u need to type the router IP address & on DNS u need to try three different settings 1st on primary DNS type the router ip address like 192.168.1.1, if it didn't work try with univeral DNS try on primary DNS as 4.2.2.2 & on secondary 4.2.2.1, if this didn't work either call ur ISP and ask for the DNS server address of ur ISP and try with that.
Jan 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 live DNS test failed
if you are connecting directly to the modem, then you are going to need to get the dns info from your ISP. If you have a router just put the router address or let it find it automatically. Also check that the router has the right dns settings from the ISP.
Jun 09, 2008 | Microsoft Xbox 360 Console
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Router and xbox 360
in the DMZ zone of your router, it has to be capable to accept incoming connections .
to access your router..192.168.1.1 in internet explorer >>> go >>> it will gonna ask your passwor d and user name(by default they are admin) >>> go to application & gaming...select DMZ...DMZ Hosting -select enable..and tipe your IP address in the form below.
You can find your IP address in Status >>> select Local network >>>> DHCP client table >>>> and you'll gonna find your PC name and IP address in there.
Jan 19, 2008 | Linksys Wireless-G WKUSB54GS Kit
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
