Question about Dirt Devil Vacuums
How do you chabge the belt in the dirt devil ultra swivel?
    Sniper:
  • 68 Answers
Attached is a copy of the link for the manual. I have included the steps here, but the manual has drawings on page 10 of the manual, it will tell you how to change the belt. You will need a phillips screwdriver.
  1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat end face up. To remove nozzle guard, use Phillips or Flat head screwdriver to remove the 5 screws. Arrows on diagram shows locations of screws.
  2. Lift nozzle gueard off.
  3. Be sure belt is off motor shaft. Lift and remove brushroll. Dispose of old belt.
  4. To Replace belt, Slide belt onto motorshaft
  5. Place new belt in area of brushroll without bristles
  6. With new belt in place, pull end slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is prperly aligned.
  7. Reattach nozzle guard
  8. Secure by aligning the 3 tabs in the base slots. Replace all 5 screws to secure nozzle guard.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=23331
Please rate this solution
Posted on Jul 31, 2008
How to change belt on dirt devil ultra handy vac
Unscrew the chrome plate from the bottom to access the belt. Watch the Brit do it on YouTube How to replace dirt devil belt on handyzip
Jul 14, 2017 | Dirt Devil Vacuums
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
How do I get the bottom of off the dirt devil swivel glide
The bottom does not come off. If. You remove the screws the top cover can be removed to gain access to brush roll, belt and motor compartment
Feb 15, 2015 | Dirt Devil Vacuums
My Dirt Devil ultra vision will not **** from base
Your belt is probably worn or broken. You need to replace the belt if you haven't recently. You can get the belts you need here:
Dirt Devil Ultra Vision Replacement Belts
Nov 07, 2009 | Vacuums
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
My dirt devile swivel upright seems to not be picking up dirt
Check the belt. If the belt is ok, check the hose and the hose that goes to the bottom part for blockage. Check if the filters are dirty.
Aug 10, 2009 | Dirt Devil Vacuums
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
I have a Dirt Devil Swivel Glide Vac with a broken belt. I have purchased the correct belt(#4).The bottom is off and I cannot tell where the belt connects to. Please help. Jann
it connects to the left side with the little metal rod sticking out.then connect to the wooden roller. in the space without the brush on it. roll the wooden piece to check if everything moves. then put back together.
Aug 27, 2008 | Dirt Devil Vacuums
Vacuums Logo
280 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
