Question about Toshiba Lands Phones
I have a Toshiba portable digital phone. I think that the model is EXP 9700. It is part of a telephone system. The portable phone shows the following error message: DKT MODE and I cannot access any telephone lines from the handset.
5 Suggested Answers
  • 38 Answers
SOURCE: Toshiba DKT-2010H Corded Phone ringing in my ear..
this is call waiting setting
must disable it from the program..
or may be some body over ride the call to u
contact the phone proviver to disable the setting
Posted on Feb 27, 2009
  • 45 Answers
SOURCE: Toshiba Telephone DKT 2020-SD
Hook switch is bad on the phone.
Posted on Apr 03, 2009
  • 336 Answers
SOURCE: How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Posted on Aug 10, 2009
cnavarro
  • 2460 Answers
SOURCE: how do i change the clock on my toshiba dkt
Since it depends on the system try this link:
http://www.telecomuserguides.com/manuals/filesupload/changetime/Toshiba.htm
Carl
Posted on Nov 04, 2009
How do I turn on the Msg indicator
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Oct 07, 2014 | Toshiba Digital DKT-2010-H Standard...
I need to install a refurbished toshiba DKT2010-SD phone to an existing phone line. all our other phones are the same model, i thought it was as simple as just plugging it in, it isn't working, what...
The telephone system is propriatary so it needs a port out of the phone system to work. you can either use a standard single line telephone (like the one in your house) and plug it into the phone line or hook the phone line up to the phone system and hook the toshiba set to the system via the existing jack.
Apr 14, 2010 | Toshiba DKT2010SD Phone
Hi, My problem is that no dialled, recived or missed calls show on the log list. what shows are the last numbers befpr the problem accured. My phone is blackberry 9700. help is needed sultan.
You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
Many quirky behaviors for these devices are fixed every time a new software version is released.
The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
Mar 08, 2010 | RIM BlackBerry Bold 9700 Smartphone
When i unlock my bold 9700 sometimes the display on the screen will be messed up. Shows a ghost set of icons on the home screen. Sometimes i'll try to type on the phone and the characters will be messed...
May I recommend ensuring you are running the most recent system software and firmware for your BlackBerry Bold 9700? This will ensure as many bugs as possible have been worked out of the phone you are using.
The latest BlackBerry Bold 9700 system software is available through here.
Feb 15, 2010 | RIM BlackBerry Bold 9700 Smartphone
Need a telephone manual
Go to the link below you can find your model on the list. Click on it to show the manual. Its about midway down
http://uniden.com/index/manuals_results.cfm?cat=1
Nov 15, 2008 | Uniden 2.4 GHz Expandable Phone System...
Can't receive a fax but can send one. My machine model number is MFC-9700
There are three different receive modes for your MFC. You may choose the mode that best suits your needs by pressing the receive mode repeatedly until the LCD shows the setting you want to use
if the setup is only for faxing no other telephone lines on the line then select fax only.
if there is a telephone on the same line your gonna want to select Ext.Tel/Tad
if you are wanting to control the phone line and must answer every call yourself by uing a external phone select manual
manual you can use with distinctive ring as well so you can know what is a fax and what is a phone call.
let me know if this works or not please describe your setup if further troubleshooting is needed.
Aug 08, 2008 | Brother Office Equipment & Supplies
Got new phone, answering machine dead?
There is no two horizontal lines error description in user manual.
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Based on my experience, I think, maybe it is related to parrellel phone dectection. ATT 1717 already think, the system is busy or in use. The line voltage is too low when you hook up other phone.
Your house phone line maybe far from switch (3km to 5km).
Dec 28, 2007 | AT&T 1717 Digital Answering Machine
Cancel camped on tones
Steve, Yes. The question is what is the model / revision level or type of Toshiba system? The Dkt-2010 works on a few and some use different "codes" or software when setting up a digital station port. I have around 30 Years Exp. on this stuff. and can still be challenged by some systems. I am assuming you are connected to a Statacom system but I would need a model nuber on the main cabinet to help. Oh, I my customer would pay $40.00 trip charge & $80.00 per hour, which I pro - rate @ 15 min. increments. Most others nail you for a (1) hour min. post a reply I will help. Bob
Sep 05, 2007 | Toshiba DKT-2010 Corded Phone
Lands Phones Logo
57 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
