Question about Denon AVR-1906 Receiver
Avr-1906 hi, I just read one of your respond and i had to ask you. I have the AVR 1906 and one day came home and will not power up. no lights or anything else. i removed the panel and both glass fuses are ok. I was hoping maybe you can tell what I should do with it. I had the unit for about 2 years and not sure if I have any warranty on it. My opinion is trash it, but I think you already know whats wrong with it... :) thanks, Here is my email if you can respond to this. ( smati000@cox.net )
    Problem Solver:
  • 13 Answers
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
(The red standby button light flashes quickly)
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 26, 2008
  • Foxyjay
    Foxyjay Aug 26, 2008
    I have fixed the amp totally but it required more components in my case - there were several resistors & capacitors etc, also gone faulty too.
    I borrowed them all from the rear centre channel PCB (i dont use these channels for now)
  • 3 Answers
Hi all, I've had the same thing with a 1906 that I bought on e-bay.
With the promise of re-imbursal from the seller, I managed to find a local (S.Wales, UK) repair shop that fixed the amp overnight for £45.00. It was, in this case a couple of dry joints causing exactly the same symptoms.
You can get it fixed professionally for little money if you find a small repair outfit, so I'd reccommend that you don't go changing transistors around unless you can tell for sure that that is your problem.
Posted on Aug 20, 2009
Can any one advise me DENON AVR 1906 stanby power supply voltage check points values & sub transformer in/out voltage values..?
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 25, 2016 | Denon AVR-1906 Receiver
No power how to solve
Check outlet for power by plugging in a known working device to the outlet. If it has power, replace the power cable of the receiver. IF that still does not work, the receiver's power supply is dead.
Jan 21, 2016 | Denon AVR-1906 Receiver
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Denon avr 1906 i cant seem to get the onscreen display to show up on my tosh 32wlt66 i have it connected through the component cables every thing is brand new and this is the first time it has been...
I found your question while searching the web for the same problem myself.
After finding a denon instruction manual online, I found out that the on screen display isn't output through the component video conection. Instead, it is only sent through the s-video or the yellow phono jack style video connections.
I connected it up this way and have seen the on screen display. But I was a little disappointed with it. It is just white text on a black background which shows the same info that you see on the unit's front panel!
Hope this helps
Dec 07, 2008 | Denon AVR-1906 Receiver
Blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
May 25, 2008 | Denon AVR-1906 Receiver
When i turn it on it startts up then immediately goes to a red flashing light i have checked all the connections following the problem page of the manual
Hope thats of use!
Apr 13, 2008 | Denon AVR-1906 Receiver
DENON AVR 1906
Units dc protect mode is probably activating due to Blown channel (shorted output transistors) I work for a Denon Authorized repair Center in Michigan If shipping to Michigan is economical let me know kstahl65@att.net
Feb 05, 2008 | Denon AVR-1906 Receiver
Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
Jan 10, 2008 | Denon AVR-1403 Receiver
Denon AVR-1906 Receiver Logo
357 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
