Question about Dell OptiPlex GX270 PC Desktop
Dell gx270 power and orange flashing light
Hi, hope all is well in your part of the world.
I have a similar issue as a post you have, in regarding the orange flashing light issue on Dell Gx270's - Did holding it in for 10secs (the power button) resolve the issue permanently? Or did the unit completly fail soon after anyway?
When i got back into the office today, one of our training rooms, which have these (second hand) Dell Gx270's had been put in the I.T room by our I.T lead administrator, with a note saying the psu was dead.
I am familiar with the capacitor issue with the Dell Gx280's (as both of these we had failed in quick sucession).
After opening the case (to inspect the capacitors) I started the unit which booted to windows fine. I was some-what surprised at this, as our Lead I.T is a geek guru, there isnt much I.T related he is ever wrong about or cant fix.
So after having the unit on for about five minutes I was thinking of shutting it down, I was doing other tasks at the time, when the next thing i know there is the Dell with the orange flashing power light (and how i found the post).
I have restarted and left four office apps open and an antivirus trying to get it to fail again, like a makeshift burn in wizard, and am currently typing this from the unit with a "dead psu" - which obviously isnt the case.
I am also wondering if you have found any knowledge, in your troubleshooting travels of these Dells that might be helpful, do they intermittently fail or they generally fail and thats it? Reason being that it isnt worth putting time into putting the unit back into production especially if its only going to fail again / soon. Or issues like there is just to much dust in the fins of the cpu and its overheating and shutting down because of the "speed step" technology that these cpus are supposed to have.
Any advice would be greatly appreciated.
Thankyou in advance
P.S
I didnt try the option of holding in the power button for 10 secs. As I havent had to try this option yet - I dont whish to introduce other elements into the equation until / if required.
  • Milazimi Dec 22, 2008
    a yellow flash i hold it for few seconds it turns of but when i try to turn on same yellow light!!!!
Try www.TheCapKing.com they have the best prices on capacitor kits, free shipping in the US, and no minimum order.
Posted on Dec 11, 2008
Hi Mikeabcde,
I'm not sure how much help I can be in this matter. When I had the problem of a dead PC, showing only the orange flashing light, I was unable to do anything with the machine. As nothing seemed to work except the light, I randomly decided to (a), just push in the button for less than a second (which did nothing, then (b), hold the button in for 5 - 10 seconds, which immediately resolved the issue. Afterwards I talked to my son who is quite a guru in these matters, and he told me that this was "standard procedure" for resetting this machine. I had gotten into trouble when I was reconnecting a CD burner power supply while the PC was on.
I believe my machine is a 2004 model, which had been "refurbished" I have to say that I could find no evidence whatsoever of any refurbishing - it looked brand new in every aspect. In researching online, there does appear to be a capacitor problem with this model, although I have had no such problem in over a year of use. I don't believe that overheating is a major issue with the Dell GX270. I have never known dust in the CPU fins to cause excessive overheating. Obviously, if the machine is located in a way which would prevent reasonable ventilation around the case, overheating might then occur, but this would be unlikely.
Replacing a bad capacitor might be a solution, although it might be difficult to identify the problem cap., since they can go bad without any visible indication. Replacing the power supply unit is a possibility, but the cost might not be justified for this relatively inexpensive machine. Good luck, Mike. Hope everything works out successfully for you Have a great day!
ewol
Posted on Jul 31, 2008
I am willing to modify your exhaust fan to give it better cooling if it is possible, but I need an exhaust fan sent to me to modify. I currently sell cooling fans on the web that I manufacture. Since this seems to be a large scale problem from Dell, I want to see if I can create a fix. It looks like the cpu overheats. Either a bigger fan or better cooling system.
Posted on Aug 22, 2009
    Problem Solver:
  • 13 Answers
I think you may have problems on your motherboard and / or power supply unit.
Everyone knows about the problems with bad capacitors, but they might not know the following:
1. They are in the power supplies just as much as in the motherboards.
2. There may be no visible signs of damage, but still be bad capacitors.
3. The problems these capacitors cause may show themselves intermittently (they come and go).
The "fix" for these is to replace each and every electrolytic capacitor on the motherboard and power supply. The motherboards have between 25 and 30 capacitors themselves.
Alternatively, you can fix the motherboards and just get new power supplies if you can find them.
If you go to this web site: http://www.badcaps.net/
You can read all about the problems and fixing the motherboards yourself if you like. They also offer a motherboard repair service as well. It's cheaper than throwing them away, or buying a new motherboard and they offer a warranty too.
They don't currently have fix it kits for power supplies, but maybe soon.
All I can tell you is that I've dealt with tons of these and in most cases, the power supply is bad too and they can "appear" to work fine at times, and they go nuts at any time. It's the nature of the capacitor problem. However sometimes they do "blow" and won't work again.
-Chip
Posted on Nov 21, 2008
Orange light on D
Ha! We used to have loads of these - if I recall, it was a network adapter error - otherwise, check the motherboard for blown capacitors, they'll be bulging or even spewing yellow gunk out the top. This was a very common issue and Dell should replace the board free of charge.
For more info, see http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx270
Oct 02, 2013 | Dell OptiPlex GX270 PC Desktop
Dell flashing orange and white
Orange flashing light, then turning to White, indicates a bad Battery.
Regards,
joecoolvette
Aug 01, 2012 | Dell Computers & Internet
What does the blinking orange light mean on my dell CPU, I can't get it to power up
dell only knows 2 colors blue and orange... if you have no light on the mother board when power is plugged in. then your power supply is probably gone. considering you didn't mention beeps I would say thats it.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 16, 2011 | Dell OptiPlex GX270 PC Desktop
Orange light on Dell GX270 power button
According to dell there is an internal power problem.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1177038
Good luck
Apr 28, 2011 | Dell OptiPlex GX270 PC Desktop
My power butten is orage an if pressbthe moniter key it says power save mode on press any key or move the mouse. When I do nothing happens. I have a wireless mouse and the little recesepter thing that...
From my experience orange power button usually means 2 possible issues. One is motherboard especially if it is model gx270 or power supply issue. Unless you really know what you are doing it will kinda be hard to determine. You can open the case and look on the motherboard to see is there any capacitors that look cracked or bloated(not perfectly round) which would indicate motherboard issue. I would take it to a pc repair shop if it is worth it and have the test it. Good luck.
Nov 02, 2010 | Dell Computers & Internet
PC is flashing orange light on power button and wount boot up
hi
you have problem with your Disply setting just change from bios it will start
May 28, 2010 | Dell OptiPlex GX270 PC Desktop
Optiplex light blinks, fan goes for a second but won't turn on
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
Aug 11, 2009 | Dell Optiplex GX270
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
Jul 07, 2008 | Dell OptiPlex 170L PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
4,118 people viewed this question
Alun Cox
