Question about Fisher and Paykel Kitchen Ranges
Is it alright to put an aluminium oven tray on the bottom of the titan double triduim ovens?
  • 68 Answers
You do not want to set anything on the element. Setting anything on the element, and turning it on will burn up the element, as well as it will probably melt the aluminum tray if it is on the element.
Please rate this solution
Posted on Jul 31, 2008
Top element not working
either a wire of the element or a faulty element
Feb 13, 2014 | Fisher and Paykel Titan OD301M Electric...
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 | Ovens
How do I prevent leakage from oven bags?
I suggest cooking food into oven bags at maximum 180 degrees celsius to prevent leakage, and for less than one hour. However it's always a good idea to put a tray or container under the bag so that in case there is some leakage, the sauce can be retrieved and it won't burn on the oven's floor. Another solution to prevent leakage is putting two bags one into the other, so to provide double protection.
In any case, whatever temperature you cook at or for however long, never put the bag too close to the sides of the oven or too close to its top or bottom. Closeness to very hot surfaces raises the chances of melting the plastic and therefore causing leakage.
Sep 11, 2013 | Home
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Sep 20, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Is it alrignt to put an aluminium oven tray on the bottom of the titan double triduim oven? Will it damage the element?
Jul 31, 2008 | Fisher and Paykel Kitchen Ranges
Oven problem
microprocessor burned out? There was a problem of this with the double ovens, after the top oven went through a cleaning cycle.
Nov 09, 2006 | Fisher and Paykel Titan OS301M Electric...
Kitchen Ranges Logo
126 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
Level 1 Expert
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
