Question about Vivitar V3800N 35mm SLR Camera
Forget how to take double pictures.
I haven't used my vivitar in some time and I remember being able to take a picture and without winding the film taking an overlap picture. Almost like a double picture. There was a button but I now unsure which one. If someone could help that would be great or had some kind of diagram that showed what each button did would be great even.
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Go Ahead. Use Us.
Posted on Jul 31, 2008
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
I have a Nikon N90S, and it stopped taking pictures after 15 shots. We stopped using the camera, and used our backup to finish the shoot. I thought that maybe the roll of film jammed, but when I...
Have you tried replacing the batteries? It sounds like the batteries may just be too low to wind film, but can function without a load.
I can't remember if the N90S has the vertical grip release or not, but if it does, have you attempted to use it, to see if the camera functions from that release, or on fully manual settings with a cable release? Are there any error messages reading out on the LCD top panel or in the viewfinder? Are you using an attached flash? What settings are you using?
If it's not functioning, on any settings including manual with film loaded, then it's most lilely in need of a visit to a repair shop to figure out where the issue lies.
But, I'd try new batteries first.
Jun 30, 2011 | Nikon N90S 35mm SLR Camera
I used my camera for 17-20 shots but then layed it aside and haven't used it again until now. Will the film be harmed? It's been over a year. That's probably a silly question but can I...
Hi Barbara - The film is actually a digital data file in a digital camera so your 17-20 photos should still be fine on the camera. Data files don't go bad with time.
You can just take up shooting from where you left off originally, just make sure the batteries are fresh and off you go.
Good Luck and happy shooting,
May 25, 2011 | Vivitar Cameras
Will the vivitar vivi cam 5385 digital camera work without the sd card?
Yes, slightly better than a film camera without film. You can take one picture and review it, until you turn the camera off.
Feb 03, 2011 | Vivitar ViviCam 5385 Digital Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
I can not get software to download and I need to
The on-line Vivitar website said that the camera has 16MB of internal memory and can take an 8mp pictures.
According to my wife's camera book (8mp Panasonic) you can take between 2-6 pictures at 8mp, 5-10 using 5mp density, and 8-16 using 3mp density. Not many.
Dec 17, 2009 | Vivitar ViviCam 8025 Digital Camera
I took a roll of pictures but the film came out blank. What did I do wrong? or what could be wrong w/the camera?
Please say what model of camera you're using.
You may not have loaded the film properly so that it wasn't wound forward after each exposure. Sometimes the film leader isn't picked up by the wind-on mechanism. Check the frame indicator moves as you wind the film on. Also operate the shutter without film and with the back open. You should see a flash of light through the lens if the shutter operates.
Oct 31, 2009 | Photography
Photos are blank, film not capturing the pictures. film put in properly
double check the back is secure, then as you take a picture - listen to hear if the is winding on properley
Jul 21, 2009 | Konica Minolta Maxxum 5 Date with 28-80...
Film fast forwards
This is normal operation for the Canon Rebel film cameras, they are designed to pre-wind the film so each time you take a picture the camera winds it into the film cartridge. This means if the camera has a problem or the film door gets opened by accident your pictures are safe in the canister.
Nov 05, 2008 | Canon EOS Rebel X 35mm SLR Camera
Vivitar PS:35 camera
Try putting a little pressure on the back door right of the finder. If the counter worked, then when film is finished and removed with the back door open you can see a metal lever in the slot that the door fits into. It should be straight vertical if not straighten with a needle or pin to vertical.. No parts are avail. for this model.
Nov 03, 2008 | Vivitar PS12 35mm Point and Shoot Camera
Vivitar V3800N 35mm SLR Camera Logo
187 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
