Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool model # ED5JHGXRBOO the drawers keep freezing our vegetables
The temperature controls are not working. We have played with the settings and unless we have so warm that nothing in the refrigerator is cold we freeze all of the vegetables and fruit we try to store in the drawers. Any suggestions?
  • rpb0117 Dec 12, 2008
    1. vegetable draw regardless of where I set the control freezes the vegetibles
  • 12 Answers
SOURCE: bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Posted on Jan 11, 2008
  • 41 Answers
SOURCE: vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Posted on Dec 12, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 226 Answers
SOURCE: Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
Posted on May 21, 2009
SOURCE: Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Posted on Jul 29, 2009
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
2 problems
Do your vegetable keeper drawers have humidity controls?
Jun 13, 2008 | GE Profile¿ Arctica® Energy...
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vegetable keep freezing in the vegetable drawer
What brand and model? If it's a GE, I see the damper door brake and create the symptoms you hare seeing. If it's a duel evaporator model, the thermistor or control bd can be bad.
Aug 15, 2010 | Refrigerators
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Vegetables freezing
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Vegetable draw is freezing the vegetables
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
123 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
