Question about HP Photosmart C6100 All-In-One Printer
HP Photosmart C6100 All-in-One
I can't seem to get my printer to print from the photo tray.  It keeps telling me to put in the paper face down and it is already there.  I am not sure what to try next.  I did not get any help from the basic guide.  Do you have any suggestions.  It has worked previously.
  • lenigaretson Jul 31, 2008
    I have an HPC6100 All-in-One printer that does not recognize when I have photo paper in the photo paper tray. I keep getting the error message that I need to put in paper. One answer was to replace or clean the roller and I am not sure where it is an if I can get to it. Is this a common problem with the HP? Also, FixYa said the paper might be too thick, but it is the paper that comes with the printer cartridges, so I don't think that is the problem.
  • 2,071 Answers
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. HP Photosmart C6100 All-in-One - s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instrucHP Photosmart C6100 All-in-One - s.gif. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Posted on Jul 31, 2008
    Genius:
  • 1,269 Answers
Try using different kind/type of photo paper? Like thinner than you were using. Also try to detach the tray put it back in.
    Master:
  • 382 Answers
Acutally theres a small error in the alingment of the Catridge and the photoTray which causes you this problem!!..So Try to remove it and fit it back properly (try to get a assistance of some one if possible)..It will possibly solve your problem...Thank you!!
Please post back for further assistance..
Kind Regards!!
  • Natesan Sabesan
    Natesan Sabesan Aug 01, 2008
    Yeah it is a common problem in printer..One choice is you can change the paper and try..Also the roller is the paper where the paper gets the cyclic movement in the printer..If your familiar then remove the catridge and then clean the roller parts and others below catridge..this will help you surely..thank you!!
    Kind Regards!!..
  • 790 Answers
Hi
you need to check the sensor! maybe this is dirty or defective!
Thanks!
  • 813 Answers
Photo paper come thik so its not come in printer u need a not so thik photo paper if paper not feed then its ur roler problem u have to change the roller or u have to clean it & try to print
Printer won't pick up paper to print or copy. paper is loaded put registers as 'out of paper, load paper face down in main tray'. this has all been done. What's wrong
If it's in the 1st paper tray, pull out the tray and check if theres a sensor. Check if it's out of position, if it is, place it back in position. If the printer still says 'load paper' the sensor is most likely faulty.
Dec 18, 2015 | HP Photosmart C6100 All-In-One Printer
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do u put the print paper in facing up or facing down printer photosmart c4750
If ordinary paper it does not matter.If photo paper then put it in the feeder tray glossy side down and one sheet at a time as glossy paper tends to stick and causes paper jams.
May 04, 2010 | HP Office Equipment & Supplies
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart C6100 All-In-One Printer Logo
221 people viewed this question
Ben Johnson
