Question about Canon PowerShot A85 Digital Camera
Memory card error - E50
Use 512mb card. Took 200 photos. received message memory card error. tried to reformat. screen has E50 in lower left hand corner. does not format.
  • Anonymous Mar 18, 2014
    Getting e50 memory card error, even after reformatting card and trying a new reformatted card.
    Problem Solver:
  • 9 Answers
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Posted on Aug 11, 2005
I have a Leica D-LUX 3. There is a an error message that the memory card is full, however, there are no pictures to delete from the card. When I go to review pictures, I get this error message: "No...
You should remove the memory card, plug it in to a card reader on a computer, and copy any photos off of it, then delete them (or reformat the card). There may be photos on the card (in a different folder, or in an unreadable format for the camera) that may make the camera think that there are both 0 photos on the card as well as 0 space left on the card.
Mar 11, 2011 | Leica Cameras
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
I have a canon powershot sx200 IS and I recently went on vacation and took a lot of pictures using teh SD memory card provided with the camera. For some reason, after almost filling the card I received a...
The likely reason this keeps happening is that these cards weren't formatted in the camera when you first got them. However, don't do so just yet as formatting also erases the card. If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. Now AFTER you've recovered the photos, format the cards IN THE CAMERA USING THE CAMERAS FORMAT FEATURE. Look for it, it's located under the "tools" menu (look for the item stating the card's memory capacity). This should rejuvenate both cards, and prevent reoccurrence.
Aug 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
I am trying to retrieve photos to print online from my Canon SD630 Digital Elph but I get a message "communication error" on the bottom of the camera screen. I am able to retrieve and print photos from...
First, I'd give the connectors on the card a buff with a soft dry cloth.
When finished, check if the card has a write enable notch on the left hand side, make sure the notch is in the right position.
If the notch is broken, cover the gap with a little sticky tape, just like you used to with tape cassettes.
if that doesn't work
You could buy/borrow a universal card reader, and connect that to your PC. Works just like another hard drive.
If that doesn't work, try you card in another compatible camera, if it still fails, your card has a problem. The only thing left to try is re-formatting in the camera and that will clear all data from the card.
Jul 10, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
AIPTEK IS-DV2
First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
Jul 08, 2008 | Aiptek IS-DV2 Camcorder
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Canon PowerShot A85 Digital Camera Logo
866 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
