Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Sony KDF-E50A10 Green picture.
I have a Sony KDF-E50A10. Originally my problem was that I could not turn it on. I would get three flashing green lights, a pause, then three flashing red lights on the power/standby indicator. I unplugged the tv and removed and reinstalled the lamp. After I did that the tv turned on but the picture has a green hue to it. Also, on the bottom right hand side there is a star effect of blue pixels. Could it be that I need a new lamp or would it be something else? Thanks in advance for the help.
  • jojieladao Oct 09, 2008
    My Sony TV SDF-E50A10 has a flashing red lights which the manual recommend for us to replace the projection lamp. I bought a Sony Projection Lamp for $199.00 and upon replacing the old lamp, it is still flashing. Do you think flashing lights mean another problem other than Lamp. Majual doesn't say anything.. Need your feedback
  • 61 Answers
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Posted on Oct 10, 2008
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
Thanks.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
KDF-E50A10 TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
# of red flashes = error code.
3x = lamp door or lamp not fully inserted
4x = fan error
5x = lamp driver error
6x = power supply or thermal fuse blown
Jun 12, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony KDF E50A10
If standby light flash 3 times that means Lamp Cover is open or not fixed properly on its place.
Please make sure lamp cover is fixed securely.
Have you replaced its lamp recently?
Thanks.
Sep 04, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Jul 10, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
Have the Ballast (power supply to the lamp) replaced.
Jun 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
355 people viewed this question
Jerry Greenberg
Jerry Greenberg
