Question about Canon Office Equipment & Supplies
I470D printer no print head indication
After changing color ink cartridge, I get a message saying print not installed
    Genius:
  • 2,785 Answers
Plz check you have installed the correct cartridge and have removed all the stickers, other wise your cartridge is defective
Posted on Jul 31, 2008
Canon i470d will not print color, checked status and settings.
Hi
Check the Printing Preferences
Start > (Control Panel) > Printer(s) > right click on Canon i470d icon > Printing Preferences > General
Select Colo(u)r Printing > Apply > OK.
Also try Nozzle Check and Print Head Cleaning:
Start > (Control Panel) > Printer(s) > right click on Canon i470d icon > Printing Preferences > Maintenance.
If these do not work, change the colou cartridge and then perform Head Cleaning and/or Nozzle Check and Head Cleaning, as appropriate.
I hope this helps.
You may need to do Head Cleaning after every cartridge change.
Aug 27, 2011 | Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Carriage cycles normally but no ink on paper.(Stylus color 880)
    Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
    Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
    Hp 6150 won't print clearly --new cartridges are in
    Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
    Hope this initial info/idea helps.
    May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HAving trouble printing
    Check and make sure you did buy the right one first.
    Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
    Message saying color ink cartridge not installed
    This is a common problem with the Canon IP90 printer. The printer keeps saying color cartridge not installed. The problem is caused by the small micro switch under the color tank. This problem is not common with new IP90 printers because ink has not had enough time to build up under the micro switch which will insulate the contacts. To cure this problem is very simple, unless you have screwed around the print head and busted the little micro switch clip off.then you really have a problem........
    So if everything is still there and you haven't messed around to much.here is what the fix is.
    First get a can of CRC Electronic cleaner for sensitive electronic equipment ,the quick drying formula.CRC#05102. This cleaner is safe and harmless to plastics. Do not use electricial contact cleaner it will disolve plastic.
    First center the cartridge carrier,shut off power . Carrier should stay to center. Remove black and color tanks. In front of the carrier is a small print head button , push it in and up and the arm that holds the head in will release. Move the small metal arm up and remove the print head.
    This will give you a clear view of the small micro switch. Using a long wooden tooth pick pack small pieces of paper towel under and around the micro switch and carriage.
    The can of cleaner should have a long plastic tube nozzle so attach this to the spray head.
    Point the spray tube right near the micro switch and spray a couple of short bursts . You will notice a lot of ink on the towel. Change the pieces of towel out ,because they will be wet with cleaner and ink. Two or three times is all that is required. Assemble and try it.
    Jan 10, 2009 | Canon PIXMA iP90 Mobile Printer
    CanonPIXMA iP90 Color Ink Tank installation problem
    yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
    part number: QM2-2020-020
    hope this helps
    Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
    Canon I470D not printing
    may be your cartridge is empty or try out head cleaning to run the flow of ink into the new head.wish u success!
    Jun 04, 2008 | Office Equipment & Supplies
    175 people viewed this question
    old marine
    old marine
    Corne Viljoen
