Question about Kyocera Office Equipment & Supplies
CF620 SYSTEM ERROR CODE ON KYOCERA KM-5050 MFP
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
leroyal
  • 2120 Answers
SOURCE: kyocera error code on a km-f1060 e03-20
You have a broken fuser roller gear that is stalling the main motor.
Posted on Mar 06, 2009
SOURCE: Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Posted on Mar 11, 2009
How i can solved the error code cfb31 for km 5050
i have the problem cfb31 in machine kyocera km 4050/5050
Dec 23, 2014 | Kyocera Office Equipment & Supplies
How to set system to print in color
KM-3050/4050/505 is a pure Black & White MFP
Oct 18, 2014 | Kyocera Tk-717Km-3050/4050/5050
Kyocera repair
press status button enter 1087 1087 then 201 start press flashing crosshairs with pen point then enter 01 start
Sep 02, 2014 | Kyocera Copystar Fax System M Km-5050...
Error cfb30
Try upgrading the latest firmware
Aug 24, 2014 | Kyocera Copystar Fax System M Km-5050...
Kyocera error cf620
CF620
System Error. Error acquiring the event data. Panel detects CF000 as same error.
Reseat Memory, F-Dimm(s)and try another HDD
Jul 21, 2014 | Kyocera KM2560 Toner 20000 Yield - Genuine...
How can i clear an error c3300?
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
Aug 25, 2012 | Kyocera KM 5050 Toner Cartridge 34000...
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Getting an error code of C6030
KM-5050 error code displaying C 6030 how can i remove this code WebRepOverall ratingThis site has no rating(not enough votes)
Apr 16, 2009 | Office Equipment & Supplies
1,267 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
