the rear blower works but the front wont blow air but I can feel the cold air in there it just won't blow out.the rear blower works but the front wont blow air but I can feel the cold air in there it just won't blow out.
We have a 2005 Dodge Caravan and the air conditioner works in the back but is not operating in the front. It is not blowing out air. What is the solution?We have a 2005 Dodge Caravan and the air conditioner works in the back but is not operating in the front. It is not blowing out air. What is the solution?
You can't post conmments that contain an email address.
Try to back wash the heater core first if it doesnt work then its clogged up try to turn the heater on the front with the heater off for the back keep an eye on the temp guage if it goes up than normal then its clogged....
Fyi u have to run the engine for awhile with the heater fan on
With your front heat working the most likely cause for the rear heat not to work is that there is an obstruction in the line that is preventing the warm coolant to get to the rear heater core or the rear heater core itself is plugged and not circulating. Another possible cause could be low coolant level where the system has enough coolant to provide the front system with enought warm coolant but not the rear system. Hope this helps
I have the same problem with my 2001 Tahoe. The front blower is working, its blowing strong, but its cold air even with the temp setting as high as it can get. The rear blows hot air. The engine temp guage is at about 210ish which is close to being normal (220). I just replaced the thermostate a few months ago, I don't know if its bad again, or it I deluted the antifreeze too much and it frooze the heater core, or if the heater core just went bad. Any one know what the cause could be?
