I have recently purchased a new p.c. i didnt want to lose my files from my old p.c so i bought a maxtor 500gb external hard drive to back up my files and put them onto my new p.c, i am a novice and not very knowledgeable about these sort of things so i would be very greatfull if you could help me, thankyou
    Problem Solver:
  • 4 Answers
Click on the my computer or navigate to the area where you can see the C:\ drive under there if the maxtor usb external drive is plugged in and powered on it should appear - the maxtor may even say maxtor in the name or properties when clicked on. but its size of 470ish? odd megabytes should e a give away this will be the maxtor especially if its not your C:\ drive.
Once identified
Open the my documents, right click with the mouse select make new folder, name it something relevant to what files you are going to place in it from the maxtor drive - you can just type this name in or click on the file menu and rename if you make an error.
Next navigate to the maxtor drive open this its icon will look similar to the C:\ drive icon its likely to be an E:\ drive depending on your units configuration.
Next double click the icon not the name to open the drive we'll call it E:\ for arguments sake. In here depending on the file structure will be your old saved data.
You can either have open the C:\ drive at the same time as the E:\ drive, so both drives contents are visible on screen at the same time - then drag and drop the files using a left click from the E:\ and dropping the files into the C:\ drives new folder youve just created.
Essentialy this doesnt need to be done as you can still access / open the older files straight from the E:\ drive.
If however you want to back up the files then drag and drop them - hold left click release when in area that you want to save file in.
Do's & Donts
Do remember to copy not cut.
Do create multiple folders with a relevant names or you could get confussed to as where your data has gone.
Do remember to create your new folders first so you dont get issues later.
Donts
If the old files are all in one big folder on your maxtor drive dont just drag and drop the whole large folder, many smaller 10 to 15GB folders with an appropriate name is preferable whilist potentially harder to manage, will open quicker than a single 110GB folder.
If you get stuck with the drag and drop method one can right click on the appropriate file once and select copy from the context menu that appears. Then double left click on the new folder and right click and paste the file..
good luck
Posted on Jul 31, 2008
  • 981 Answers
It's important to lose your files from time to time, but you can also use a migration tool to help you, or just pull the drive from the old machine to keep spare in the new machine (and put a fresh drive in the old machine unless you are going to recycle it.)  Imaging the old drive won't work if you have much encryption going on.
  It's simple to observe: Know what you're doing!  Read books on PC operating systems (e.g. bsd and windows) and keep very good track of what you want to preserve and what you could be doing better.
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch 4, 500GB
Access http://www.maxtor.com and click "support" and download the file(s).
Mar 26, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor Harddrive Disconnects
get a new external drive and transfer all the files to the new drive.
Jan 14, 2009 | Maxtor OneTouch II external hard drive...
My Files on my external hard drive are saved as compressed files.
just copy them to the laptop and, asuming the folder you are using is uncompressed they shoudl expand. Or highlight the files rightclick on them and fo ro properties
Jan 13, 2009 | Maxtor Hard Drive
Maxtor formatting
i have a maxtor my computer crashed and i lost my disk how do i get my pictures back
Oct 05, 2008 | Maxtor OneTouch A01B080 80 GB Hard Drive
External Hard Drive
Couple of questions first: -What operating system was running on the new and old PC? -Is the old PC still running and available? Once you answer these we?ll start work.
Mar 04, 2007 | Maxtor OneTouch A01B080 80 GB Hard Drive
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
