Setting up linksys wireless router with motorola 2210 dsl modem
I get all green lights on both the dsl modem and the linksys router, but cannot connect to the internet. WRT600N Dual-Band Wirelwess-N Gigabit Router
    Scholar:
  • 67 Answers
Reset the DSL Modem and make sure the modem is setup for your DSL account information. You might have to call up your ISP for that information to be added. If that was done prior then the Router has to have the same information user name @ your ISP.net or .com and password. for PPOE. Make sure the router has it MTU set to 1492 for DSL.
1. unplug the modem
2. unplug the router
3. between both of them wait 30 seconds
4. all PCs should not be on
5. plug in back the modem
6. plug in back the router
7. Turn one one PC
8. login to the router and make sure it connects to the internet
Since your using Gig Router make sure that the WAN is to 10 if you have 6Mbps plan 15 to 30mbp plan go to 100 for WAN.
If you're still having issues, then you need 3rd level service tech from your ISP to check the DSL back at the office side to see how that's connecting to your modem. If that checks out okay, then have line tech come out and check the DSL going into the house. If that checks out good then it could be the a problem with the new router you have there you have updated the firmware for it yet?
If you have then the modem could be the problem. These are the steps you need to take to trouble shoot the problem. Check all connections make sure they're plugged in correctly. Make sure all DSL filters are working correctly one bad filter can throw the DSL off. Check each phone connected to a filter to see if its clear.
Posted on Jul 31, 2008
    Master:
  • 382 Answers
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router...
hope this helps you..
Thank you!!...
My new WRT160N Linksys won't connect ATT Motorola 2210 DSL Modem
For AT&T default IP address for the Motorola modem is 192.168.1.254.
Default for the Linksys IP address is 192.168.1.1.
Have you changed either one? For them to work correctly they need to be in different subnets. An IP Address of 192.168.y.xx, where y is the subnet and a different number for each device, usually 0, 1, or 2.
If they are in the same subnet, change the modem'smag-glass_10x10.gif IP to 192.168.0.254 or 192.168.2.254. Once you do this you will need to use the new address to access the modem.
You should make sure the router'smag-glass_10x10.gif gateway is outside the DHCP rage of the modem.
Dec 06, 2010 | Linksys WRT160N Wireless Router
All lights are green on my DSL modem except the internet light which is solid red. I called AT&T for help ( My modem was a brand new combination router/modem from Netgear with wireless N) and after a...
If you have ATT DSL they should be supplying the DSl Modem. Unfortunately they supply Motorola 2210's, which systematically burn out due to overheating. The symptom is that the DSL blinnks, but the other lights to the right of that will not come on. That means it is sending requests to the network for service, but the receiving section is unable to receive the reply.
I am on my 3rd 2210 in 3 months. ATT do replace them free, but they really need to switch to a different manufacturer.
Aug 23, 2010 | Arris Netopia 2210 ADSL2+ Modem SinglePort...
Linksys router will not connect with motorola 2210 modem
Your problem may be timing.
Make sure you have all your cables connected correctly.
Do not have power to either the modem or router.
Plug in you modem and watch the lights go to work. Wait for them to settle down. Now plug in your router, again watching the lights. It should work now.
You can download Linksys' LELA program to monitor the network. Shows green lines to your computers, etc. when working and red lines when not. It will also give your status and make suggestions if you loose your connection.
Good Luck
Feb 24, 2010 | Linksys Wireless-G WRT54G Router
How to bridge my motorola 2210 DSL modem & linksys wrt54g router
Try these insturctions. Jump to page 109. http://www.netopia.com/support/hardware/manuals/SoftwareUserGuideV751Clsc.pdf
Aug 21, 2009 | Linksys Wireless-G WRT54G Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
1,084 people viewed this question
David Payne
David Payne
