Question about RCA Universal Remote Control
No puedo programar el control universal para mi tv.
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): no puedo programar el control - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Como se programa el control universal janesong js-188
tengo un sankey lcd de 32 pulgadas y no se como programar el control universal janesong f-188
Feb 12, 2012 | Televison & Video
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Mi caja convertidora es zenith y quiero programar el control de la caja convertidora con mi television zenith
como puedo conseguir el control remoto de mi caja covertodora se me descompuso y no puedo programar mi senal
Jan 30, 2011 | Abt Television 1745 Remote Control
Como puedo programar mi control de dish en la segunda tv la tv es panasonic
Hola mi nombre es Mayra Diaz con DISH Network. La manera m?s f?cil para programar el control de DIsh a su tele Panasonic es siguiendo estos siguientes pasos. Presione el bot?n de blanco de TV hasta que las cuatro luces se han prendido luego presione 700,734,673, siguiendo con el bot?n # localizado abajo del 9. Ahora intente subir su volumen para verificar si funciona. Los tres c?digos se tienen q tratar individualmente siguiendo los mismos pasos. Si tiene alguna otra pregunt? por favor escribanos.
Dec 13, 2010 | DISH Network IR Remote Control
Codigo para programar control rca para un dvd
busco el codigo para un dvd gpx, mi control es un rca universal
Nov 23, 2010 | GPX D1816 DVD Player
Como programarla ala tv
Hola mi nombre es Mayra Diaz con Dish Network. Con much gusto le puedo ayudar a programar su control a su televisor. Primero que todo necesitamos saber cual es la marca de su televisor para darle los c?digos que funcionen con su televisor espec?ficamente.
Aug 15, 2010 | DISH Network IR Remote Control
Como programo la caja del dish
Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
Aug 04, 2010 | DISH Network IR Remote Control
Televison & Video Logo
325 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
