Question about Garmin GPS
My IQE 3200 has stopped working and even when it is on it keeps telling me to use the stylus to tap at a cetain point on the screen, when i do that it does the same thing again nothing else happens. The hot sync cradle has been lost as well so if I get a new one will it reactivate or is it just dead and gone? Or is the battery fried or what?
  • oldnag Jul 31, 2008
    we also have a Garmin Nuvi 350 and we have lst the preloaded sd card for the U.S. can we buy the updated 2009 one and use it instead or how do we resolve this?
    Been there done that, I read the manual that came with it it has NO trouble shooting guide at all for my IQE 3200. Do I have to have the cradle to charge it or is it just dead!!
    Master:
  • 382 Answers
I hope you are speaking of the problem of card not being recognised too..so please visit the following link which can bring a lot of light on the topic to you..
http://forum.brighthand.com/showthread.php?t=220927
I end up refering you to a link because the solution is feasible to be explained!!...Thank you!!...
Posted on Jul 31, 2008
  • Garmin Master
  • 13,433 Answers
Try reseting the device, it may be that the digitizer the touch component above the lcd screen has failed, and would need to be replaced. I recommend you contact garmin for possible repairs, do you have warranty on it? if so they would fix it up for you.
you can also look for the replacement part from ebay.
www.ebay.com
under ique 3200
    Master:
  • 763 Answers
Maybe the main hardware of your device have cause trouble.
try to read the operating instructions on the link that ill post, download it and be sure you have a pdf reader to read what contains inside. see the other support on this website. hope that helps!
http://www8.garmin.com/products/manual.jsp?product=010-00297-00
CHARCOIS
Palm zire stylus not working
Try doing a soft reset on the pda, this will usually resolve the issue. Then reperform the aliginment task.
Jun 10, 2012 | Palm Zire Mono M150 Handheld
When i turn my ds on it goes to the action replay before anything pops up it turns white even before datel shows up
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing up on the POWER switch.
    3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
    5. Tap the Options icon.
    6. Tap the Start-up Mode icon.
    7. Tap the top box for "M Manual Mode" and tap the "Confirm" rectangle.
    8. Wait for the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Mar 25, 2011 | Datel Action Replay for Nintendo DS
I try set up phone but stylus does not work on screen what can i do?
Use button and go to tap - settings from menu, then tap your screen. Stylus will work.
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 600 Handheld
Touchscreen not reacting to stylus but the buttons work ok
  1. urn on your HP iPAQ Pocket PC.
  2. Use your stylus to tap on the "Start" menu.
  3. Tap on the "System" tab.
  4. Tap the "Screen" icon.
  5. Tap the "Align Screen" button.
  6. Tap the center of the cross-hair object carefully at each location as it moves around the screen.
  7. Tap "OK" to complete the screen alignment.
Mar 28, 2010 | HP iPAQ rx5915
Icons in the screen cannot be directly pointed. "if you click a specific icon the other near icon will respond"
Go into the Display inside control panel. In the second tab, choose Calibrate screen. Once done, it should work properly
Jun 08, 2009 | Sony Ericsson P910i Cellular Phone
Stuck in stylus tap
Electronics fugar. Get another from your provider.
Aug 29, 2017 | Samsung SPH-i500 Handheld
Solution
You have to press firmly on the screen with your stylus for it to respond, if it does not then it must be a problem with the touchscreen digitizer.
Jul 12, 2008 | HTC S710 Smartphone
New to htc
The half-white screen is definitely not a good sign. The "hold and tap" screen you see is the alignment screen normally seen at a "fresh" startup.
If this is the PPC6800 Mogul, there is a small pinhole reset button on the bottom of the unit. Using the stylus, push the button, This will "soft reset" the unit.
If this doesn't work, you can try hard resetting it:
1. Press and hold both softkeys on the device. (The soft keys are the buttons to the left and right of the center navigation wheel with the white dots on them) Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
2. Release the stylus but keep the softkeys pressed when you see the following message on your device screen:
“Do you want to erase all user data and restore to manufacture default?”
3. Slide open the keyboard, and press R to restore to factory default or press X to exit the hard reset process.
This may take a few tries, as it's hard to hold the buttons and push the reset button.
Jun 11, 2008 | HTC TyTN Smartphone
Ipaq wont open
The iPAQ will keep cycling through this alignment screen until it registers all five points correctly. Try cleaning the screen with a micro cloth and if necessary a little conventional glass cleaner. Then careful click on each of the X being careful to just click the center and not drag the stylus. Even the smallest movement across the screen will cause the registration process to fail. If that doesn?t work try doing a cold boot and restart the process.
Apr 08, 2007 | HP iPAQ hx2410 Pocket PC
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
