Question about Curtis Mini Shelf System Shelf System
Curtis Radio/CD Player Model RCD718
This sytem will do nothing . The red light comes on but no other function worker manually or with the remote I have pushed all the buttons and nothing has worked. Prior I put in a CD and got message no CD. Had to put a book under it to blance. I changed location and tried another plug and still get nothing.
Remote won't work but can manually operate
you do the camera tricks just to ensure if the infra red sensor of the remote is working. get a digital camera turn it on,then get the remote controller. press any button at the remote controller pointing to the digital camera, if you see a light at the display of the camera then the infra red sensor is good but if no light either the sensor is worn out or the circuit was defective.
Dec 07, 2012 | Curtis DVD1041 Player
I have a Vizio TV and comcast cable. I connected the red yello and white to each end, plugged in the curtis 1041d dvd player. The lights come on and the tray ejects and goes back in both manually and by...
there is a problems on the loding sensor swichtes there is two plastic toggle switch inside needs to clean it. used wd40 none static cleaner for electronics devices.
May 30, 2011 | Curtis DVD1041 Player
My remote broke and im trying to get the codes for it for my dish network remote. Do you know them ???
Sorry to hear about the original remote, we would be happy to help with getting your DISH remote programmed to your Curtis DVD player. Here is a list ofcodes that should address your DISH Network remote to your Curtis DVD player: 678, 679, 683, 585, 592, and 594. Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Curtis DVD player, thenpress the pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your DVD player. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, pleasetry the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 01, 2010 | Curtis DVD1047 DVD Player
Radio wont come on
There should be a reset button on the unit. That would probably be the first thing I would look at.
Feb 09, 2009 | Kenwood KDC-MP238 CD Player
PROGRAMMING GE UNIVERSAL REMOTE MODEL JASRM24912 FOR A zENITH TV
Leave me your email and I will send you the Original manual and Codes for this remote GE JASRM24912
May 04, 2008 | GE JASRM24912 Remote Control
Codes
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
Feb 21, 2008 | Televison & Video
Wont turn on
No, most units will at least work basic functions without a remote. What is the make / model? I would take it back as soon as you can.
Jan 19, 2008 | Audio Players & Recorders
I need help! jensen 3610
Hmm, did you hook up the red ignition wire?
Oct 20, 2006 | Jensen CD3610 CD Player
240 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
