Question about Palm TX Handheld
Hotsync the Hotsync cord seems to be stuck how do you get it out i see no clips or buttons to release it. whats the right way to remove it i see no instructions on it
  • 2,794 Answers
It should gently pull out. Is it seated into the port properly?
Posted on Jul 31, 2008
Show a diagram on how to get cd stuck in 2006 f150 out. Cd stuck and tried but it won' come out
Look to see if there is a tiny hole on the front of CD player just under the tray.that is the access point for a paper clip.if there isn't one...try turning ignition off then whilst holding the eject button turn on the ignition and do not release eject button.
you may need to try this several times.what you are trying to do is beat the cd from trying to read the cd as this seems to over ride any eject commands on some machines.if all of the above fail you may need to remove entire unit from dash to gain access .
Feb 12, 2015 | Ford F-150 F150 Extended Cab
Smart card stuck
Remove the power cord. Doublke-check that you removed the power cord! Use a butter knife to gently press in on the smart card in a push-to-release effort. Then insert an unfolded paper clip along the side of the smart card and try to nudge it outwards.
Aug 14, 2014 | HP EliteBook Computers & Internet
How do I remove the cord from the block heater on my 2009 envoy. It seems to be stuck on & I can't just pull it off
have u tried to reset it sometimes those do that /acc fuse or a fuse for just that/or try disconnect bat. for moment.there shoud be a clip at the end u have to push in then up on some
Jan 24, 2013 | 2009 GMC Envoy
How do you hard reset on palm treo 755
Hard resets on a 755p are described in the user's guide as removing the battery (with the phone off, and screen off), and then pressing the Navigator-UP button and holding until you insert the battery again, and you see the Orangle PALM logo displayed, where you can release your Nav-UP button. This does not work.
You need to hold down on the red power button, until the Orangle PLAM logo shows up, release it, and you will see a question like "do you want erase all of your data?" , press the Nav-UP button, and it will now do a clean hard reset.
Now, on the backup folder.
If you do not change user-names, and your PALM Hotsync setting for 'Backup' is set to 'Desktop overwrites handheld' you will get everything back when you HotSync. Therefore, if you delete the problem App's from your Backup folder (ie C:\palm\755p\backup, where 755p = your HotSync name) and you change to the settings on 'Backup' to 'Desktop overwrites Handheld' - then when you hotsync, you'll get the app's you want back, and not the ones you do not.
I hope this makes sense.
Sep 18, 2009 | Palm Treo 755p Smartphone
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
My son's Treo 650 powers on (keypad lights up but screen does not light up.) My son attempted to switch the case from the silver to a black and now it will not work. Help?
it may need a software rest if it don"t work go to reinstal software first chake it out
  1. Hard reset:
  2. Press and hold the Power (on/off) button on the front panel of your device.
  3. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  4. If you see a progress bar (see below), keep holding the Power button.
  5. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  6. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
HotSync note:Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Jul 04, 2009 | Palm Treo 650 Smartphone
My Palm Treo 600 is stuck on and frozen in the camera position. Usually I would get a paper clip and stick it in the reset hole on the back and it would reset allowing me access to all functions of the...
Hi elg
There are many ways to reset your Treo, here are some from Treo KB themselves...
# How do I perform a hard reset on the Palm Treo 600?
HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
1. Hold down the power (on/off) button on your device.
2. While holding down the power button, turn over your device so that you can see the back of it.
Using an unfolded paper clip or a similar small object, gently press the RESET hole on the back
3. When the device's screen displays the Palm Computing Platform logo, release the power button.
4. A message will appear warning that you are about to erase all the data stored on your handheld.
In response, do one of the following:
* Press the UP button to complete the hard reset, erasing everything on your device
or
* Press any other button to begin a soft reset, leaving your data intact.
5. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not reset the current date and time. It does restore other settings to the factory default.
Back to top
# How do I recover after a hard reset?
If you backed up your data by synchronizing it to your desktop computer, you can restore it now by performing a HotSync operation.
1. Since all data was erased by the hard reset, first synchronize your device with your desktop computer.
1. Make sure your conduits are turned to "Synchronize the files" or "Desktop overwrites handheld". Do not turn conduits to "handheld overwrites desktop". This will erase data on your desktop computer, and you won't be able to transfer it to your handheld.
Note: Data restoration may take some time. The HotSync operation will be faster with a USB connection, slower with a serial or IR connection. You won't be able to perform a network HotSync connection until you have performed at least one successful 'local' HotSync via USB, Serial or IR.
Re-install third-party software, if any.
2. Third-party software (applications, hacks, themes, games, databases, eBooks, etc.) might not have transferred back to your handheld during a HotSync operation. Locate any missing original .prc or .pdb files on your desktop computer, and double-click the files to re-install them. For more information on how to install third-party software, visit the Palm Support Knowledge Library.
Caution: Sometimes, the reason you needed to perform a hard reset was because of third-party software. While we encourage users to take advantage of the thousands of third-party titles available, we cannot guarantee that the third-party software will be compatible. If you recently installed software and then experienced a problem, maybe you should not re-install that software. For more information on how to diagnose third-party issues, visit the Palm Support Knowledge Library.
Re-set your preferences.
3. The System conduit restores your preferences for display, menus, auto-off, and other functions. However, if there are other preferences (such as those set within third-party themes) that haven't been restored, now is the time to do so manually. Refer to the third-party software documentation for instructions.
Back to top
# How do I perform a Battery Disconnect Reset?
A battery disconnect reset is a last resort step you can take to cut battery power, wipe out all data, and bring a Palm Treo 600 back to its factory-fresh state.
A battery disconnect reset will erase everything on your device, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything.
Additionally, you won't be able to turn your Palm Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset if you're not near a power source and your Palm Treo 600 charger.
HotSync note: Some third-party applications change the way your handheld backs up data, while other third-party applications do not back up data at all. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
1. Disconnect your Palm Treo 600 from the AC charger.
2. Hold down the K and Backspace keys simultaneously.
3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device.
* Note: Palm made this type of reset very awkward to perform, so that it would not happen by accident when your Palm Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to enlist the help of a dexterous friend if you find it too difficult.
4. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens.
5. To revive your Palm Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging.
6. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is a type of hard reset).
here are the links:
http://support.vzw.com/devices/palm_treo_600_smartphone/faq.html#item15
http://kb.palm.com/wps/portal/kb/common/article/887_en.html
http://mytreo.net/how-to-guides/hard-reset-the-treo-600/
regards,
voodoo
Jun 11, 2009 | Cell Phones
Treo frozen with Treo logo on screen
  1. Hard reset:
Thanks, Joe
May 22, 2009 | Palm Treo 700p Smartphone
99 astro , upper rear door latch stuck on right side. can the latch assembly be reached from the interior ?
Ok here is what I just did. From the inside I removed the handle bolts and the two screws on both ends. (Be sure the other side is pushed in and latched). Then I used a punch and removed the two hinge pins on the roof. ***WITH SOME HELP*** push the release button. Careful for the door will pop out due to the cylinders pushing outward. At that point I removed the molding to access the latch. *Note---there are two more screws on both ends of the molding.* From the inside you can now reach the latch and release it. Again be careful the other cylinder will push out and the door will drop until it reaches the end of the cylinder stroke. Now you will need to re-pin the hinges at the top. From there I located the broken plastic clip that caused all this discuss. I temporarily removed the latch so I can still use the van until I get to the parts store plus it seems as if it will be easier to replace the clip. GOOD LUCK ! ! !
Apr 12, 2009 | 1999 Chevrolet Astro
TREO 650 can't see the computer
Did you try opening the hotsync manager and configuring your details?
Oct 01, 2008 | Palm Treo 650 Handheld
Palm TX Handheld Logo
22 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
