Question about Microsoft Office Outlook 2003 for PC
Orkut virus ive got this virus which keeps sayin "orkut is banned......"....even the task manager AND regisrty editor BOTH are disabled by this virus too....it keeps sayin registry editor and task manager are disabled by the administrator even though I AM the administrator n i never disabled all that...plz help pranay
    Scholar:
  • 67 Answers
Grab these programs they're all free.
download and install then run them...
1. Regprot run the RPAdmin make it active and install
http://www.diamondcs.com.au/freeutilities/regprot.php
2. Anti-Virus from www.pctools.com (free version one)
Run number 2 first it will update and scan the system.
3. Threat Fire from www.pctools.com (free version one) this adds another layer of protection from viruses, spyware and malware.
4. Firewall Plus from www.pctools.com (free version one)
These will run on Server, XP and Vista.
Posted on Jul 31, 2008
Task Manager is disabled. We want to enable the Task manager in my computer
If it (Task Manager) was not disabled by the Administrator (in case your computer is on a network), you can easily enable the it. But you need to know that this could also be done by viruses. As we know, this issue is often created by virus. So I would suggest you to run a full system Scan using an updated antivirus (for this problem, I would recommend you to use Avira free antivirus, you can download it from avirafreeantivirus).
To enable the Task Manager, follow the below instructions:
Click “Start” > “Run” and type in “gpedit.msc” (without qoutes) and press Enter.
Group Policy Editor window will open, once it’s opened, follow the steps by clicking your mouse as labeled here (sequence 1, 2.....):
Once you double click the "Remove Task Manager", another window will pop up, click your mouse as labelled below (Sequence..):
After you are done, close the Group Policy Editor and go check your task manager, hurray, it's working.
But that's the end, the problem may return if your system is infected by virus, so don’t forget to run a Full System Virus Scan using an updated antivirus.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | Computers & Internet
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Task manager is disabled by administrator
So your task mananger isn't working, this may be a Virus, or simply some programs error? Anyway, If you have Windows XP Pro, there's a nifty user interface to directly edit the setting you want to repair. Click Start, then click Run and type in gpedit.msc: And press OK. This runs the Group Policy Editor. Once in the Group Policy Editor, expand in turn: User Configuration Administrative Templates System Ctrl+Alt+Del Options You should see the Group Policy Window, Double click on Remove Task Manager to change its setting: It should be enough to click on Not Configured and then OK and Task Manager is available once again. If you don't have Windows XP Pro, then you'll need to edit the registry manually. Click Start, then click Run, type in regedit, and click on OK. Expand these registry keys in turn:
HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Policies \System You should see the key DisableTaskMgr in the right hand pane. Right Click on the DisableTaskMgr item: Click on Delete, confirm that you want to delete, and Task Manager should be available once again. One thing to note is that it's quite possible that if you're in an environment managed by a centralized policy, these settings may have no effect. Your IT administrator may set things up so as to disable Task Manager, and other things as well at the domain level. You'll need to ask them if this is the case.
Feb 17, 2010 | Microsoft Windows XP Professional
DVD-RW optical drive not working properly
The two symptoms could be attributed to a viral activity. Some viruses will disable your CD/dvd burner for the reasons you cannot make a backup copy with your important files.
I suggest, it is safer to scan your harddrive using another clean computer with a good antivirus and malware remover.
Even I too experienced that everytime when you access cmd,msconfig,task manager, sytem restore, registry editor there's some kind of counter. Until you reach the number of times you access that it will release its destructive job. For me it also block me of using USB, even floppy.
Commonly this is a Vundo activity. Many free antivirus can disinfect this. Disinfecting directly from its own hard drive. But the risk of your important files is the priority that is why I suggest to it using another computer. But it is your call.
I recommend Avira, malwarebytes antimalware. Install, update then scan. And still check your DVD burner for hardware defect.
I think this should be enough. Just ask again.
May 29, 2009 | Computers & Internet
I m getting message for banned sites like orkut, youtube..
YES! It is a virus.
I suggest you get a good anti-virus program and run a full system scan.
There are a few suggestions here that may help also.
http://support.mozilla.com/en-US/kb/use+Internet+Explorer+messages+upon+Firefox+startup
Trend House Call is a pretty good online program.
Apr 04, 2009 | Computers & Internet
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Computer virus
this is virus dear that come from orkut,but dont afraid just scan your pc if it does not detect then try another updated antivirus
also scan your pc with adaware & spyware tool
if still have problem then remove yur internet explorer using control panel & under remove window componenent
then istall it using window cd under extra programs or additional tasks
Nov 15, 2008 | Intel Motherboard
Pc problem..pls help!
you definitely have a virus in your pc, it disables your task manager, registry editor, even the command prompt.
solution:
update and run a complete anti virus scan of your pc.
You may have to edit your registry after the scan, to restore any errors done by the virus. BE CAREFUL.
http://ask-leo.com/why_is_my_task_manager_disabled_and_how_do_i_fix_it.html
There are also a lot of tools that would fix your registry for you like combofix, flash disinfector and regfix http://windowsxp.mvps.org/reg/EnableTM.reg
Mar 05, 2008 | Computers & Internet
Serious TaskManager Problem!!
Task Manager can be disabled by 2 main ways..
[1] Either there is a virus on your machine--
[2]Or It was manually disabled.
--The 1st solution is to get an anti virus which is up to date and run a virus scan to delete the viruses that maybe present.
--The second solution is that on your START MENU, click on "run".
On 'run' type "gpedit.msc"..
Under the "User Configuration" , click on " Administrative Templates"..
Then you double click on "system" .Double click on "Ctrl+Alt+Del Options"... Double Click on " Remove Task Manager" and click on "Disable"... Click on "Apply" and "Ok"
Your Task Manager should now work !!!
Jan 03, 2008 | Computers & Internet
Registry Editor, Task manager, Command Prompt Disabled
hi, your computer is attacked by virus .install some antivirus and scan the system to resolve this problem .
Dec 17, 2007 | Microsoft Windows XP Home Edition
Microsoft Office Outlook 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
