Question about Dishwashers
Maytag Dishwasher circa 2002 - Defective Plastic rollers The plastic rollers that slide the arms of the dish rack keep breaking. I have had this dishwasher for 6yrs now and go through 1 a year. This defect is really annoying for two reasons one; the cost - $50 each - X's 6 years = $300. Secondly, the inconvenience of having a delapitated dish rack that crashes sideways - with the weight on only one side. Presently, I'm about to order my 6th one. I'd like to know if you are aware of this defect? Has there been a breakthrough in somehow beefing up the plastic so it doesn't do this anymore? Has there been any change in this roller part? Surely, I can't be the only one. Respectfully, Cheryl Lamb
NJFIRESTORM
  • 84 Answers
SOURCE: Trying to replace broken upper rack adjustment arm . . .
first off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
Posted on May 12, 2008
  • 171 Answers
SOURCE: Replacing Rollers on GE 725
Hi bklink_2000,
I'm Harvey the Master Plumber.
Your problem is: Now that you have the rollers you can't see how to get the old ones out or the new ones in. You are worried that if you forced the plastic piece out at the front of the steel rail you may bend the rail.
You're on the right track! The plastic end caps should pop off, that,s what they're for.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
THENTHEREWER
  • 131 Answers
SOURCE: ge pdw7880j10ss dishwasher lower roller
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
SOURCE: rollers on racks continue to break, Maytag fix is buy entire new assembly like part number 99003585 wihich is 32.95 each time
I found an engineer who has made stainless steel axels for the rack...www.fifengr.com/maytag/....a cost of $40...but well worth the one time solution....
Posted on Feb 10, 2009
SOURCE: Broken rollers inside top rack slides
We got rollers recently from Johnstone Supply, 501 Third Avenue, South, Nashville, TN telephone 615-259-3440 or 254-0702. I don't know the cost, but I'm pretty sure it was not $72. I suggest that you have the model #.
I am planning to buy some for another dishwasher at the moment.
Posted on Apr 12, 2009
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
How do I repair the upper rack slide on a Whirlpool W10431033A dishwasher.
If it's like my Maytag there appears to be a plastic bump or catch on the outside edge of the slider. A very hard push on the catch should allow you to get the cap out of the end of the slider.
Jan 13, 2015 | Whirlpool Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Residue on dishes Dish washer is maytag Dwy 7402 aab purchase in 1996 Soap residue, cleaned top spray arm, but cannot get the bottom off, is there a trick to it without breaking the plastic
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 18, 2010 | Maytag MDB5100A Dishwasher
Dishes in lower rack are not clean
on most there is a small plastic pice in the center of the arm turn it clock wise hold the arm
Jun 01, 2010 | Maytag MDB7100AWB Dishwasher
Upper rack spray is clogged
it has a pressure insertion fitting that snaps into the arm thru the hole,you need to press in on the ears on the bottom of the are to release the plastic grips to let it drop out,then the arm should remove after this
Apr 19, 2010 | Maytag MDB5100A Dishwasher
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Jan 19, 2009 | Maytag 24 in. MDB9750AW Dishwasher
May 12, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
