Question about Kenmore 22422 Top Load Washer
Agitator removal we have a dress tie wrapped around the agitator .. can we remove this ourselves.. its a kenmore 800 series.. it has the fabric soften dispenser and both types of agitation. .. i tried to remove the softner dispencer myself and couldnt get it off.. does it come off? help please ..
    Novelist:
    Champion:
  • 261 Answers
Yes it does, I believe the dispenser will twist an 1/8 turn and pop off. There is a cap with a handle below it that pulls out. The last part is a bolt. Try a 7/16 deep well socket with a nine inch extension, grasp the agitator and loosen it. Leave bolt intact and lift agitator from the bottom. Looking from the date if you have solved the issue this will stand as a general post for ag removal.
Posted on Nov 01, 2008
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
the dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Nov 08, 2014 | Kenmore Washing Machines
My washing machine only turns one way now. it
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Mar 15, 2010 | Washing Machines
I need to remove the agitator to replace the agitator dogs but there is no bolt head to unscrew is there a special tool for this model 11022912101 series 90
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22912101&pathTaken=partSearch
look at the diagrams for the agitator, basket and tub and you should see how the top components of the agitator fit.
Mar 13, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Following is an illustrated description of the above.
Jan 09, 2010 | Kenmore Washing Machines
Dual action kenmore 70 series washer need to remove agitator
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
I have a kenmore top load washer, The top part of
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Also see the following on how to do it.
Oct 28, 2009 | Kenmore Washing Machines
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Amana ALW780QAW mold in agitator
actually sounds like fabric softener residue with dirt mixed in...it's almost like a wax if thats it. probably just have to clean it regularly..good luck! :)
Jun 14, 2009 | Amana ALW880WH Top Load Washer
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
305 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
