Question about Philips 60PL9200D Projection Televisions
Power Our tv screen went black and the blue button on the front had a red dot on it.
    Genius:
  • 2,035 Answers
Try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.
Posted on Jul 31, 2008
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Philips 60PL9200D Projection Televisions Logo
545 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
