Question about Steam Fast SF-250 Mouse Vacuum
Can't open lid where water goes in
Lid seems to be reamed out when trying to turn. Any advice
  • LilaMae217 Sep 16, 2008
    I was just using my steam cleaner when I noticed there seemed to be a little steam coming out of the opening under the cap. I turned the thing off and let it cool, but now the cap will not come off. I've taken that cap on and off a hundred times and now it just spins and won't come off.
  • missguided1 Oct 02, 2008
    Same problem opening fill cap. It spins - but when I push down it will not move or the entire reservior seems to move. Always worked before and pretty sure it was empty when last used....
My Hoover SteamVac F5915-900 will not pick up water. I've taken the resavor off several times trying to make sure nothing is under it's lid and replaced it as instructed. I don't know wh
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC VACUUM UP THE WATER AGAIN.
Jul 21, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac will not **** up water
Check the lid on the lower tank. The front of the lid lips over the tank to lock it on and snaps in the back. You probably haven't locked the front edge down
Apr 29, 2010 | Hoover F5810 SteamVac Upright Vacuum
Vacuum sounds funny and doesn't have any suction.
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have lost suction.....what do I do? -with the vacuum and the hose!
Its okay to unscrew where the hose is connect to the area close to the bottom, where the hose bends. That is where there is usually a ball of hair, dust, and whatever. Pull the hair ball out and also clean the roller.
Jan 12, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson seems to have lost suction?
If the usual clog clearing and filter cleaning doesn;t work-> I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Nov 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Doesn't seem to have as much section as when new. Is there some routine maintenance I should be doing?
Nov 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
CAN,T REMEMBER WHERE THE WATER GOES
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
May 11, 2009 | Steam Fast SF-250 Mouse Vacuum
Hoover Steam Vac Model F5826-900
When you put the lid on the recovery tank, you have to be sure that the front of the lid is properly engaged into the two tabs on the top of the tank. With the lid installed, if you can lift the front of the lid off the tank with two fingers, then the lid is not on correctly. Also, make sure the square duct that goes into the front of the tank is in place. You have to remove this duct to install the hose for doing furniture but must replace it to go back to the floor function. By the way, the "blowing air" you refer to is normal. This is exhaust air from the motor and it is used to propel the solution onto the carpet.
Feb 19, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My steam cleaner want suck the water up
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Also make sure that the lid is on correctly and not loose one end.
Dec 26, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Steam Fast SF-250 Mouse Vacuum Logo
85 people viewed this question
Top Steam Fast Vacuums Experts
JoeVacs
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
