Question about Dishwashers
Kenmore dishwasher model #587.1551590 want pump out water
  • Anonymous Nov 18, 2008
    My Sears dishwasher model 587.1551590 leaks out extra water as well whenever it runs. Any suggestions on how to fix it?
SOURCE: Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Posted on Nov 01, 2007
SOURCE: kenmore ultra wash II model no. 1691190
YOUR MAN WAS OF ABSOLUTLY NO HELP IN SOLVING MY PROBLEM. I ENDED UP CALLING SEARS AND THEY SENT A TECH OUT. YOUR MAN SAID TO TAKE THE DISHWASHER OUT AND TURN IN ON IT'S BACK AND I COULD ACCESS THE PUMP. THE TECH SAID THIS WAS NOT TRUE. YOU CAN ACCESS THE PUMP FROM THE INSIDE OF THE DISHWASHER. IT IS APPARENT TO ME THAT YOUR TECH HAD NO IDEA ABOUT THE MACHINE. AS IT TURNED OUT, THERE WAS NOTHING WRONG WITH THE DISHWASHER. IT HAD A KINK IN THE DISCHARGE HOSE.....P
Posted on Jul 21, 2008
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
bigg t
  • 640 Answers
SOURCE: New Kenmore Dishwasher Model 587-1401 has a toxic smell
Use a descaling agent.Clr (calcium,lime,rust) remover availiable at super markets,drugstores.Pour a cup in and run a couple of cycles.When finished keep the door open to air dry.
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: My Kenmore quiet guard standard model 587-15152400
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Posted on Aug 22, 2010
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
Purchased 2007, Kenmore UltraWash d.w. makes loud buzzing noise that stats about a minute after 'start' and continues most of the time throughout cycle. Think it's the pump? Can't easily get it to be...
Please provide model number of the kenmore dishwasher.
Is there water in the base when the wash is complete? There could be couple of pumps in some Kenmore dishwashers - so hard to know which one until model number is known.
Dec 06, 2010 | Kenmore Dishwashers
Water does not go out
Dishwasher will not pump out water. Replaced timer. Still same problem. Checked discharge hose - no issues. What next? How to check / evaluate. Timer cost me $100, and was not the problem. Help. Broke.
Aug 28, 2009 | Kenmore Dishwashers
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Model 15754 Kenmore built in dishwasher leaking water into basement
take off the bottom panel ....... check for the leak .... could be the fill valve connection ..... motor pump assembly (most liklely) or a drain hose/pump issue....if the DW is noisy as well go shopping ...
Jul 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher (model 655) not draining
when i attend dishwashers that have lost power to some part, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time after that check the outlet pump which is often a separate part to the main motor, this pump could be faulty electrically
Sep 27, 2007 | Dishwashers
Kenmore dishwasher
fatubu, are you sure you have the correct model number, Im not finding anything on the posted model. They had an issue on models close to this that had an issue with a twisted or missing seal in the pump assy. causing water to fill the pressure switch hose. The dishwasher would drain water after the fill. The fix was to replace the pump and motor assy. Catriver..post back.
Feb 18, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
231 people viewed this question
Top Dishwashers Experts
