Question about JVC AM FM CD DET FACE CAR STEREO
JVC Car stereo problems
I've had this system for years. But awhile ago my radio stopped working...I could turn it all the way up and theres nothing, just static. Now my cd player doesnt work. I purchased it at Best Buy awhile ago with a warranty, but now they say I didnt have one, plus I need to buy a new one. Is there any way I can get some suggestions on how to fix my radio, everything in the back of the box is hooked up correctly still...is there certain buttons I hit or something please help. Thanks.
  • Hillary M Aug 25, 2008
    I'm having a similar problem -- I thought it was just my antenna when my radio reception started getting patchy, but last week, my JVC just stopped working -- no power, no nothing -- & with a CD still in the player
  • Anonymous Mar 13, 2009
    I have the same problem, nothing but static!
pnevai
  • 48 Answers
SOURCE: JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
SOURCE: cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
Posted on Nov 10, 2008
  • 7 Answers
SOURCE: JVC KD-G396 wont Play any cd or mp3 PLEASE HELP
take it back
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: JVC KD-G340 Power Problem
yellow wire is another power wire that goes directly to batt.,red goes to acc. or fuse box & black is ground
Posted on Mar 04, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: This problems has happened two times in the last 2
There was probably a bad connection to the power supply. There are three wires. RED is battery(12 volts at all times)YELLOW or ORANGE is acc.(12 volts when key is in acc position) BLACK is ground(connected to any metal part of the car). Pull out the stereo and make redo these connection and makes sure they are right this time.
Posted on Aug 11, 2009
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
I have a jvc kd-r311 radio in my car which has been working for about a year now, but a few days ago it came up saying "protect" on the front and now doesn't work, I've tried pushing the...
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
Aug 03, 2011 | JVC AM FM CD DET FACE CAR STEREO
Jvc car radio
Speakers have a tendency to change characteristics. Take the radio out and carefully disconnect one by one speaker. Don't disconnect all of them if you don't know which wire goes where. Then try increasing volume to the cut off limit. You may be lucky to find the speaker that cause the trouble.Try a different speaker prior to unit repair attempt
Jan 21, 2010 | JVC AM FM CD DET FACE CAR STEREO
This problems has happened two times in the last 2 months. When I put a CD in the player it plays fine. I stop somewhere, turn the car off, with the CD still in the player and when I restart the car the...
Aug 11, 2009 | JVC KD-G230 CD Player
Stereo wont work with engine on
best thing is to pull the radio out and check the red and yellow wires red wire is the egnition switch and your yellow is the always on for your memory if you like you can connect the red and yellow wires to the yellow one that will work with engine on or off but every time you get out the car you will need to turn the radio off manually i sugest pulling the radio out and checking the 2 leeds as far as you can it could also be a fuse gone but it wouldnt work when enging is off so not sure except check the wires your engition switch doesnt play up does it like your dash clocks go off and on while driving headlights etc? need more information please
Dec 19, 2008 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G200 won't power up any more.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
Nov 16, 2008 | JVC KD-G200 CD Player
Trouble with car stereo
Hoang00, to change the time on JVC's i believe you hold down "source" for a while and a menu pops up.
SSwaim, sounds like a grounding problem. Check the connections behind the dash, possibly a couple came loose. I would say possibly a bad car battery but the headlights thing points to a grounding issue to me.
May 10, 2008 | JVC KD-G310 CD Player
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
201 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
