Question about Kenwood KAC-9102D Car Audio Amplifier
The amp doesn not power on
I have an amp. Kenwood KAC-9120D I got it from somebody and I don't know if it is broken or not I hooked it up and does not turn on. If it is broken how much would be the fixing cost? Thanks.
  • fere79 Aug 01, 2008
    I already checked the connections, I assume is something wrong with the amp. Might be blown. In case it is damaged I was wondering how much would be the fixing cost.
    I checked the voltages, the multimeter says 12.5v.
    Novelist:
  • 100 Answers
First off I would double and triple check the connections to make sure everything is making good contact. The first place I would look is the ground. Make sure it has a clean paintless contact to metal. Then use a multimeter and check the voltages on the amp. If you dont have a multimeter borrow one or buy a cheapy one that has digital read out. You can get one for like $5 its a good tool to have.....when your head unit is on go to the amp and put the black lead on the ground and the red on the battery input. It should say about 12 volts and then put the red lead on the remote lead and it also should say 12 volts. If there are voltages there then there is something wrong with your amp and unless you paid more than $800 then it probably isn't worth fixing but if you are interested I could try to find you a place that I could get a quote. If there isn't voltages there then fix your wiring. I hope I could help. Good luck
-Andrew Hawkins
Posted on Jul 31, 2008
  • Andrew Hawkins
    Andrew Hawkins Aug 01, 2008
    I would say that the cost of you sending it in and just having someone look at it and them sending it back is going to be more than a couple hundred. I did a search and I found a guy selling 2 of these for $300. If you are willing to pay a few hundred just buy a different amp. Sorry. I know you said you checked the connections but did you check the voltages? connections can be deceiving......
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Cant get but one side to work
This amp (kenwood  819)  was designed for use with a sub-woofer, hence the single chanel. It will however power up 4 speakers in mono, and if they are capable of handling the amps.while robbing you of the benefits of stereo as well as left, right and fade control.Good luck...
If you still want it connected. You should purchase an amp installation kit, and review the topics and videos at this web site. www.installdr.com
Good luck...
Feb 24, 2009 | Kenwood KAC-819 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
126 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
