Question about SanDisk Sansa e200 MP3 Player
The jack for the headphones is loose can this be repaired
  • carpie09 Sep 11, 2008
    sound only plays on right when plugged into headphones and car adapter.
  • 3 Answers
Posted on Aug 03, 2008
How to use headphone? I entered the headphone socket but the sound is not come out the Head phone
Aug 16, 2013 | Samsung I9100 Galaxy S2 Speaker Headphone...
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
Feb 22, 2013 | Apple iPod classic MP3 Player
Hi! I have a brand new Coby headphones (haven't been a month). I've been keeping good care, but today I found that left ear works perfectly while right one is loose. As I turn the jack at the end around...
try cleaning the connecter
10 Headphone Repair Hacks - Sustainablog 19, 2015 - For instance, here's a file for a new jack cover. Reconnect a wire to the lead. If audio is only playing through one side of your headphones, then a loose or disconnected wire is the culprit. Repair the ear cushion. If the cushion wears out or comes off of your headphones, don't worry-that's fixable! Replace the ...
Jan 21, 2018 | Coby CV-190 Consumer Headphones
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
The headphones crackle, tried several different headphones, no better. I have to twist the end of it to get it to work. The slightest bump will make it crackle again.
This happens when the headphone jack gets rust on its surface or it is loose.
Clean the jack using a tissue paper on matchstick (or a similar thin object). Be gentle or you may destroy it!
If cleaning did not help you may need to replace the jack. Contact for repairs or if you have experience in soldering, you can purchase a replacement jack online (search ebay) and solder it in.
Jan 29, 2010 | Sanyo Audio Players & Recorders
Hello, headphone jack is loose, i have to hold the jack and press ir against an angle to make both chanels work. walter
Hi Walter,
If the headphone jack is loose you can try to use the USB headset (If there is one) or Bluetooth.
If you wanna fix the headphone jack yourself you can find a very good step by step guide here.
The repair service will take about anything from 40$-60$ to repair it.
Good Luck!
Nov 17, 2009 | SanDisk Sansa E280 MP3 Player
ok well i am thinking that if you wiggle around the headphone jack you might get it. i believe you have a few loose solders and i hope that we have found the problem, i have a samsung yp-p2 and the headphone jack is loose and the lyrics will fade out basically and become unclear, so your headphone jack is probably loose.
Apr 17, 2009 | Apple iPod nano
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
Headphone jack out
Where are you? There is a good repair center in Penrith. But that's no good to you if you are in Wyoming.
Jul 03, 2008 | Archos AV700 Digital Media Player
Headphone jack
Your best bet is to find a shop that repairs Ipods. Your headphone jack is breaking away from the printed circuit board and needs resoldered. Shouldnt be too expensive. My shop would charge $25-$40 for a repair like that.
Sep 08, 2007 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e200 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
