Lan wireless card
  1. why the speed is1mbps but it in realy 54mbps?
  • 113 Answers
Thats the 1mbps is the adsl down load speed or the transfer speed ur service provider provides u. that from exchange to router. 54 mbps is the transfer of data rate  bw ur router and computer
Posted on Nov 04, 2008
Need setup disk for f5d7010
Go to
Jan 09, 2013 | Belkin Micradigital F5D7010 54Mbps 80211g...
My network card is only allowing 54mbps , I have 1.5gig dsl with a 300mbps router Do i need a new network card the driver is updated to last update
Your wireless network card is more than sufficient to handle the bandwidth provided by your DSL connection. A "1.5" DSL connection refers to a 1.5Mbps DSL line. Your network card is an 802.11G network card. Simply put, your network card will only run at a maximum of 54Mbps, far short of your 802.11N router's maximum speed, but provides more than enough room for the bandwidth provided by your Internet Service Provider. Gigabit connections (connections with speeds measured in 'Gbps') are almost exclusively for private networks or corporate networks with Fiber Optic connections.
In layman's terms, you can get a newer network card for your computer that will improve the speeds between your laptop and any other computers on your network, but as long as your network card is supported by any modern operating system, odds are it is able to transfer data fast enough to keep up with your DSL connection
Nov 25, 2010 | Toshiba PA3235U-3BTM Network Adapter
TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC): signal strength 85% green but tx rate 11 instead o...
Im sorry but you will never get 54 on your card toughs are theoretical maximum speeds and I have never seen a system actually achieve them the actual speeds received by wireless devices are actually much lower and 11 is a normal speed wile running over wireless. Im sure this isnt what you wanted to here and I am sorry but it pretty much comes down to manufactures lieing by telling you it goes to speeds that can never be reached.
I hope this helped.
Thank you,
May 16, 2010 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Belkin wireless n route only puts out 54mbps
The reasons you only get 54mbps could be: one, your networked PCs don't support N-mode and broadcast in G-mode, so that the router falls back to 54mbps.
Two, the signal strength is too low or the radio noise level is too high to allow N-mode operation at full speed.
So, after checking with the manuals and vendor brochures, you should try connecting the router with a single PC close by - say, ten feet in the same room - and check connection speed. If you can connect at 108 or 125 depending on which N mode you have (N, N+, N1...), the problem is likely to be distance, walls or noisy equipment.
If you still can't connect, double-check the configuration of both router and PC (wifi board "Advanced Properties" in Hardware Management) to check whether N mode is enabled at BOTH ends, especially "Wireless Mode" in the PC.
If it still doesn't work, I'd test it with a Belkin N USB key, for example, just to check that when router and client vendors say, "802.11N", they do indeed refer to the same thing. That's not so cut and dried a thing as one would expect. The N-mode standard was not completely defined from the start, so that many vendors jumped the gun and implemented their own "N-modes" which are often NOT compatible with each other. If you had a US Robotics router and a Yuwasa (and outdated SparkLANs, IIRC) wifi board, you'd discover that you could only attain 11 mbps - and if the USR router was set for "G only" or "G and N" instead of "B, G and N", you would get no connection at all.
Oct 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet ,...
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
Mar 09, 2009 | HP Compaq nc6000 Notebook
What does the speed refer in wireless G 54-Mbps
It's maximum throughput of wireless network.
You can find a deep discussion on the subject with any search online or here
Jan 13, 2009 | Computers & Internet
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
It appears you are using a 802.11b WI-FI card (either at the PC or the Access Point side). If the card is a 802.11g instead, check out the settings to verify 802.11g is enabled. Regards.
Jan 29, 2008 | Dell Latitude D600 Notebook
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
