Question about Cobra 148 GTL 120-Channels Base CB Radio
Micgain when ever I turn my micgain up the it make a hight pitch sound.
  • Ronnie152 Mar 09, 2009
    mic squeal when mic gain is up all the way, used to not do this, problem just started, using any mic same thing.
My SWR is 1.1 so I thats out of it. Where do i find the regulator and the switching circuitry?
Posted on Jul 31, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, pls try:
  • If the high pitch sound (feedback) occurs during the receive, then you need to check the switch inside the microphone and verify that the audio line is not directly connected mic element wire; it should pass through the switch. Alternately, it may be the switch that is shorted. If you are using a power mic, you may have to lower the settings a bit or decrease the gain;
  • If the feedback occurs during transmit, you need to check the TX/RX regulator and switching circuitry. In some cases this would also be true if you are using a linear amp and the grounding is not adequate and/or the SWR relatively high.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch sound
this sounds like the microphone is picking up feedback, if you are not using the mic then go to control panel then sound and disable the microphone
Apr 19, 2014 | Acer Aspire 5735-6694 Notebook
Can you tell me what size rafters i need for a 4.1mtre . with a 20 % pitch and a pirlin just of center
if you have a pitch of 45 degrees you can use the 345 concept
if hight is 3 4 would be span and 5 would be rafter .
Nov 03, 2013 | NRS Rafters Glove Blue/Black, XXL
I own a 3 year old Husqvarna 2348 riding mower. Mid way in mowing I turned off the mower and refilled the gas tank. When I tried to start the mower, there was a hight pitched "whirling" sound...
At first glance it sounds like starter is not engaging just spinning they usually don not give us a warning they just go at the wrong place and time. Take it off and bench test it to make sure or take it to your local repair shop or maybe even auto zone they will test it for you. Good Luck...
Aug 30, 2011 | Husqvarna 23 Hp 48" Deck Yard Tractor
I need to know what knobs turn which way and what buttons need to be on
Volume/Squelch control: As desired
ETone: Sets the sound of the echo as desired
MicGain/RF Gain control: Normally, leave fully clockwise
Band Switch: for CB, turn all way to left (a/e)
Mode Switch: Selects how you modulate the radio. Normally, you will operate on AM, USB or LSB.
Fine/Coarse control: Changes the frequency you operate on. Normally, set so the frequency counter reading ends in 5. (center slot of the channel).
Buttons:
RB: Roger beep. Turn on or off as desired.
NB/ANL: Noise limiters. Leave on.
Frequency Counter: Turns counter lights on and off.
+10 KHZ: Allows you to get the channels missed by the Channel knob. Normally, leave off.
Power: Selects either high or low transmitter power setting.
Band: Selects band of operation. Low (A-D) or High (E-F)
Jun 12, 2011 | Galaxy Radios DX- 88HL Base CB Radio
When I transmit on my RCI-995DX people on the other end say that my transmition is scratchy and crackley. I made sure that I as on frequency. Any suggestions? The radio is less than a year old.
Hi, my name is John. Welcome to FixYa. Turn your MICGAIN down a little, or if you have a modulating mic, turn it down. Thanks for choosing FixYa...John
Nov 24, 2010 | Ranger RCI-2995DX Base Scanner
My projector tv wont turn on no more.... we got a new lamp but a guy told us it's the engine light... do you know how much it will costs to fixed it...'' thanks
hi
no panic first did you had a hight pitch noise
comming from the back like a fan would do?
if so the problem is not the light engin but the
color wheel that is defective 80$ and will not allow to power up the tv otherwise the light engine cost is close to 400$ in exchange
Sep 28, 2010 | Toshiba Televison & Video
High pitched sound from TV
Ur hight voltage flyback transformer is dead.
U need a new one.
Aug 20, 2009 | Samsung LN-T3253H 32 in. LCD Television
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
Cobra 148 GTL 120-Channels Base CB Radio Logo
104 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
