Question about Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-TFT-LCD Television
We have a big box in the middle of our TV that says not available in current mode and we can't get it off. Please help. Thank you.
  • 1 more comment
  • eady Jul 31, 2008
    I will be glad to pay for a solution.
  • Anonymous Sep 09, 2008
    I have the same window pop up. It on every video source including
    standard cable.
  • shadowripley Oct 20, 2008
    when playing my ps3 i get a box in the middle of the screen saying mode not available why is this
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Posted on Apr 19, 2009
  • 41 Answers
Check to see what resolution your source is. This model is only set for a max of 720P. If you are attempting to use a 1080P source then that will appear. Try to lower the resolution, if you are using a progessive scan dvd player, turn on the progessive scan.
Posted on Aug 08, 2008
I CANT LOGIN TO SERVICE MODE TO MY TV SAMSUNG LN-R328E PLEASE HELP ME
Unplug,replug tv back in about an hour later.Every setting,should reset now.All functions,should work now.Not,than the Tuner board,that the board have the incomming broscasting signal cable plug into it,have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Jul 30, 2010 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung ln-t4053h 40in lcd will not power on
my samsung when switched to the hdmi inputs comes up with a box saying not supported mode?? how ever shall i play my ps3 now?? can anyone help??
Feb 08, 2010 | Samsung LN-T4053H 40 in. LCD Television
No Sound on Samsung HDTV? But there is a picture...
Push the MUTE button on the TV remote to restore audio.
Nov 18, 2009 | Samsung LN-T3253H 32 in. LCD Television
Samsung LN-S4051D goes on and off by itself. Repeatedly.
1 Bad inverter circuit (used for back lighting the LCD panel)
2 Bad secondary power supply too the inverter circuits
Especially if its a switch mode power supply connected to twin phase inverters. This problem almost always happens under that particular engineering scheme. Switch mode power supply's are horrible at sustaining high voltage CCFL back lights.
Your tv needs professional servicing!
e-mail me if you need more info or advice....
Jan 28, 2009 | Samsung LN-S4051D 40 in. LCD Television
I have a samsung LN-T2342H TFT-LCD television and it does not program all of the digital stations available in the area. I have anohter brand of tv at the same location and it auto programs many more...
there isn't much you can do to solve this problem with the tv by itself. the auto tuning program has preset tuning sensitivities implemented by the manufacturer. the only thing you can do at this point is boosting the signal through a signal booster or a powered antannae so that the tv can pick them up.
Sep 15, 2008 | Samsung Televison & Video
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Box right in the middle of my tv-
make sure it is turned off on the tv and the cable box. if that dose not fix it it may need a main board
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
When vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Not Available in current mode
you could a pinch in the wire going to button assy
Apr 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Samsung LN-S3251D 32 in. LCD HDTV Logo
401 people viewed this question
Henry  Thomas
Henry Thomas
