Question about Microsoft SideWinder Force Feedback Wheel Wheel And Pedals Set
Where do you get parts for MS Sidewinder wheel/pedals
Where can i find a spring for my gas pedal. It broke on me the other night. I have checked hardware stores and cant find anything close.
Get a raquet ball and cut it in half and glue it in under the pedal to where it will come back up when you let off the gas you might want to remove the old spring though that is up to you
Posted on May 07, 2009
1984 F-150 accelerator pedal stuck to floor after shutting off--will not release
1984 if I remember is a carburetor so you should have a throttle linkage return spring. Check to see it's not broke or stretched out, also check the choke return spring that that is not stuck.
Nov 17, 2017 | Cars & Trucks
The spring broke on the leg extion can this be replaced?
Yes measure the spring and you local hardware store (ace hardware etc.), should sell the same size spring
Jan 11, 2016 | Furniture
Gas pedal no
yes,rust collapsed the hinge section,due to leaking windscreen
Jul 26, 2014 | 2003 Ford Escape
Prodigy paperpro spring broke and it stays closed
If you can get the original spring out, it's possible to buy a few common sizes of springs in hardware stores or departments. If you can find one of similar size, it should not be too hard to replace it. You may be able to pry it open with a small, thin, slot screwdriver. If a replacement spring is a bit too long, wire cutters should be enough to cut it shorter and pry out a curl of the spring to hook through the attachment point.
Jun 28, 2014 | Staples One Touch Executive Stapler
I would like a picture of the pedal stand were there is the break pedal and the cluk pedal. my problem is that whan i press the break pedal it isn`t coming bake. to see if ters a spring or somthing that...
yes there is a spring , look up part on auto parts store and u will see what it looks like. it may have broke and is still there, open door and look up at pedals spring is way up there.
Mar 28, 2011 | 1994 Volkswagen Golf
Older night owl nexgen monocular,powers up but cant see anything
try to resold it's dry pins and carefully check out it's display ribbon try to find unsoldered joint area or broke area.
Dec 21, 2010 | Night Owl Optics NONEXGEN-W Monocular
Carbator spring is broke
Try your local hardware store, a good one should have an assortment (where they keep the nuts and bolts) of little springs, both types-compression and expansion, you might be able to find one that will work.
May 02, 2010 | McCulloch FHH25A Gas Pressure Washer
Gas pedal broke loose
check where the cable attaches to the throttle body there is a plastic clip that goes to a ball on the throttle more than likely it is broke there.
Mar 04, 2009 | 1995 Ford Explorer
Microsoft SideWinder Force Feedback Wheel Wheel And Pedals Set Logo
421 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
